Shudder on Accerlation
Old Dec 1, 2014 | 12:20 PM
rahawk79's Avatar
12 TL FWD 30k on it, I recently picked up a shudder while under acceleration (seems most noticeable when it down shifts).
Initially Tein Stech on stock struts with an alignment...no issues, ran normal
Hated the feel and ate 2 struts in no time...Switched to Megan C/O drop is about 2.5-2.75 it was after that I noticed the shudder
Do you think it can be the CV/Axle, would the drop change the angle enough to cause issues ?
I obviously need an alignment again...but do you think that alone would cause the issue ?
I read somewhere we have soft motor mounts, another culprit.. it does shut off a tad bit rough just as the motor is shutting down
Old Dec 1, 2014 | 12:30 PM
you're listing WAAAAAAY too many variables for us to narrow it down.
you'll need to get that alignment done. then, narrow it down even more.
Old Dec 1, 2014 | 03:24 PM
also, read up on the torque converter.
Yikes
May 3, 2021 04:29 PM
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
justin7779
Dec 25, 2015 10:33 PM
Skirmich
Sep 15, 2015 06:41 PM
01bluecls
2G CL Problems & Fixes
20
Feb 5, 2009 05:31 PM
