Self diagnostic mode help
Old Jan 23, 2016 | 10:28 PM
Acu08's Avatar
6th Gear
Greetings, my 08 TL just started going into self diagnostic mode every time I start the car, end up showing red "HFL" and "NG". And then getting stuck on the screen.
Anyone know how to fix or disable this screen from coming up? All input will be greatly appreciated.
I actually just bought the car not up to a month now, besides this issue everything runs well, warranty company said navi system is not covered.
Old Jan 23, 2016 | 10:35 PM
Acu08's Avatar
6th Gear
The above is what the the screen look like.
Old Jan 25, 2016 | 06:56 PM
Acu08's Avatar
6th Gear
Solved!
Old Oct 14, 2016 | 01:11 PM
gavaline's Avatar
3rd Gear
Solved!
My 05 RL has this screen on starting the car. How do you PERMANENTLY get rid of this screen? I can hold Map/Menu/Cancel keys for a few seconds to reset. But when I shut the car off and then restart it, I'm back to this diagnostic screen again.
FRUSTRATED!!
Old Oct 16, 2016 | 11:39 AM
Acu08's Avatar
6th Gear
FRUSTRATED!!
After taking mine to dealership and was told to replace the Navi system below. I did research online and the steps below solved my issue.
Hold down the buttons (Menu+Map/Guidef Cancel) for about 5 seconds (the "Select Diagnosis Items" screen will appear). Hold down the Map/Guide button for 5- 10 seconds (A screen with a "Complete" button, will appear). Touch "Complete," and then the "Return" button (the system may re-boot). Restart the vehicle, and confirm normal operation.
Let me know if this work for you.
Old Oct 16, 2016 | 07:36 PM
gavaline's Avatar
3rd Gear
Thanx for the info. Gave it a try. Everything worked as you described but did not solve the problem. Shut the engine off and restarted - back to diagnostic screen!!!
Old Oct 17, 2016 | 01:02 AM
Acu08's Avatar
6th Gear
I'll try go over in my again tomorrow and see if there was anything I did differently, will get back to you.
Old Oct 18, 2016 | 11:37 AM
Acu08's Avatar
6th Gear
I checked mine and the "complete" was grayed out. I would check again and see if it changed back to incomplete. Also mine started because I was messing with the navigation CD, I would try using a different disc if you have one and then try those steps again. Good luck!
Old Mar 22, 2022 | 08:26 AM
MASS 08 TL's Avatar
Has anyone had success with this?
Every start up mine goes directly into self diagnosis mode. I hold the Map, Menu and Cancel buttons at the same time and it goes away but comes back up when starting.
synth19
Jun 18, 2026 09:45 AM
Aug 16, 2022 05:52 PM
newlybird17
Nov 25, 2016 11:28 PM
Misterfuzzy1234
Jan 22, 2016 06:08 PM
E39
Jan 8, 2016 05:47 AM
