Rust Trim pieces
Old Oct 29, 2011 | 05:14 PM
alienstudio's Avatar
Rust Trim pieces
Need some help here...
i am experiencing yellow dots on my roof trim pieces, to me it looks like rust. Is there any product out there that can remove the rust spots?
Old Oct 30, 2011 | 10:18 AM
Qwikhas's Avatar
You might want to see if the dealer will change them out under warranty. That doesnt sound normal.
Old Oct 30, 2011 | 01:38 PM
I was really surprised to see those rust spots...
I only had the car for a just over a month.
Old Oct 30, 2011 | 06:37 PM
weather's Avatar
There is no way that those rust spots are real rust spots. I suspect they are spots from the dust from the brake pads or environmental fallouts.
Old Oct 30, 2011 | 09:08 PM
I tried cleaning the trim pieces with car wash soap, and there was so luck getting rid of those yellow spots.
I don't want to believe it is real rust spot either, the trim pieces on my 04 EL still looks like brand new with no yellow/rust spots whatsoever. This is the part where i don't understand.
I am going down to my dealer next week and let them have a look.
Old Oct 31, 2011 | 10:54 AM
JLH's Avatar
JLH
Acura uses stainless steel for the trim pieces(I read this in one of their promo articles). Both anti-magnetic and magnetic stainless steel exist. Acura uses the magnetic therefore it contains some iron which may be the cause for your "rust spots"
Old Oct 31, 2011 | 01:18 PM
potmilkz's Avatar
do you live in a apartment complex where you park underground?
Old Oct 31, 2011 | 05:51 PM
i live in a house, and i park my car inside the garage, and the garage is about ground level.
Old Oct 31, 2011 | 05:55 PM
thx for the information JLH. I am going down to my dealer this week and let them check it out what is going on with my trim pieces.
i hope it is nothing serious, and the spots can be polished away with some sort of cleaning product.
Old Nov 4, 2011 | 09:52 AM
jnc2000's Avatar
It'll come out with metal polish.
Pick yourself up some Blue Magic metal polish. Dab a little on a microfiber, buff and the buff to a shine. Same thing if you have chronic water spots on the same chrome pieces...
http://www.amazon.com/BlueMagic-400-...uct/B000BO8Z9I
Old Dec 13, 2011 | 03:51 PM
Sav2010TL's Avatar
9th Gear
I had this problem when I first brought mine home from the dealer. Looked like rust spots ( I think they sat the car next to a sprinkler for a while). I used Never Dull wadding polish. They sell it at any auto parts store. Came off very easily and after one year hasnt come back.
Old Dec 13, 2011 | 08:07 PM
andvari's Avatar
Stainless steel usually contains large amounts of iron, typically 70 to 80%. The difference between magnetic and non-magnetic is determined by the ratio of the other components to iron which affect the crystal structure and thereby the magnetic properties.
Corrosion of the type described is usually due to contamination of the surface of the metal during manufacturing or by defects in the crystal structure at the metal surface that result in a chromium poor area (subject to corrosion) on the surface. During manufacturing various cleaning processes aka passivation are used to removed this contamination.
From Wikipedia:
"A typical passivation process of cleaning stainless steel tanks involves cleaning with sodium hydroxide and citric acid followed by nitric acid (up to 20% at 120 °F) and a complete water rinse. This process will restore the film, remove metal particles, dirt, and welding-generated compounds (e.g. oxides)."
Basically the yellow spots are a manufacturing defect caused by contamination followed by not doing a good passivation. Bad Acura. Bad bad bad!
Sometimes manual cleaning will fix it up. Otherwise complain to the dealer. It's not your fault.
Old Dec 13, 2011 | 08:34 PM
Teddybear's Avatar
Subsonic
if u use metal polish, make sure it doenst touch the paint!
i'd suggest u mask it off well beforehand!
for paint rust spots, i use claybar to take it out. it might work on the trim pieces. ?
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
rhdune16
Sep 28, 2015 11:31 AM
