Rpm problem and accelerating hesitation please help!
Old Jul 17, 2019 | 07:57 PM
elietania's Avatar
Hi i have a 2009 acura tl sh awd automatic 180k and im thinking my torque converter started to give me problems but im not really sure if its that... i uploaded 2 videos on youtube that shows the problem if you can check them out thank you!!
symptoms: 1-my rpm goes up and down while driving
2-the car will shut off on red light when the rpm goes to low.
3- there is some hesitation while accelerating at higher speed because the rpm is going up and down.
here the videos
Old Jul 17, 2019 | 09:55 PM
dopeboy1's Avatar
The inconvenient truth
Any lights on the dash? Get them scanned?
Old Jul 17, 2019 | 10:03 PM
elietania's Avatar
No light
Old Jul 19, 2019 | 03:19 PM
csmeance's Avatar
do the idle relearn procedure and check the fluid level of the trans when it is HOT/Warm. Fluid should be between 2 dots on the dipstick and should be pinkish red. If the rpms keep dropping really low its a bigger issue maybe a failing sprag clutch inside the transmission.
Old Jul 19, 2019 | 05:13 PM
dwest1023's Avatar
Sounds like a torque converter problem. I believe there was a recall on this. I think you need to make a trip to the dealer.
23109VC
Jul 22, 2021 09:08 PM
lhb4
Nov 19, 2006 08:07 AM
Motohip
Jun 15, 2006 11:19 AM
UWgrad
Jun 23, 2005 06:27 PM
UWgrad
Jun 23, 2005 02:18 AM
