Reverse
Old Nov 1, 2012 | 11:54 AM
Bmoreaj's Avatar
Reverse
Hey guys
I have an 09 Tl fwd, I put my car in reverse and it cut off. It's almost as if its not getting gas. Has anyone experienced this or knows what is wrong...I'm pissed its to close to Xmas for major repairs...
Old Nov 1, 2012 | 12:30 PM
ShadeTreeMech's Avatar
Did this happen on a flat surface or an incline?
Old Nov 2, 2012 | 06:39 AM
Bmoreaj's Avatar
Flat & incline on flat surface it sputters then cuts off on an incline it just straight cuts off....I'm worried this is going to cost a fortune
Old Nov 2, 2012 | 06:41 AM
more details please.
does it do it all the time?
or just one occurrence?
Have you done any work to it recently?
Bought the car new or used?
What kind of gas do you use?
Old Nov 2, 2012 | 08:00 AM
Bmoreaj's Avatar
Well when I put it in reverse it feels like it wants to cut off when I hit the gas it sputters then cuts off. It happens about 95 percent of the time...I also notice when this is happening all my lights dim in and out..
Old Nov 2, 2012 | 08:06 AM
^when did you start noticing this?
when was the last time you changed the battery?
what kind of gas do you use?
you're leaving a lot of details out.
Old Nov 2, 2012 | 10:48 AM
potmilkz's Avatar
does the car turn over fine? it is best to just bring to dealer right away so you dont do anymore damage. if it happens 95% of the time.. im sure you can replicated the issue on the spot.
quick question.. was there any repairs done on the car recently? accident? frame damage?
Old Nov 2, 2012 | 10:52 AM
^yeah, if he didnt answer my questions.......
Old Nov 3, 2012 | 03:30 AM
Edward'TLS's Avatar
6G TLX-S
How old is your battery ?
Old Nov 3, 2012 | 01:13 PM
Bmoreaj's Avatar
I notice it 2 days ago went to go back up in a parking spa e and it cut off.
Only work I've had done is TPMS I brought it used I've had it since June.
I replaced the battery in the middle of August.
So yesterday I'm playing around with it I put in reverse abs just sat there with my foot on the brake. Watching Ron's go up down like it wanted to cut off but the it kind of smooth out, since then it hasn't cut off but when I first put it in reverse the rpm dips then goes back up..I gotta feeling when I get it to a dealer it won't happen.
Old Nov 3, 2012 | 01:19 PM
Bmoreaj's Avatar
No accidents according to the car fax.
Old Nov 3, 2012 | 01:29 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Called PayPal?
Old Nov 3, 2012 | 05:05 PM
Bmoreaj's Avatar
Huh?
QUOTE=princelybug;14141107]Called PayPal?[/QUOTE]
Old Nov 3, 2012 | 05:36 PM
HEAVY_RL's Avatar
Originally Posted by princelybug
Called PayPal?
Old Nov 3, 2012 | 07:40 PM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
Based on past experiences with other cars, it may be the case that when you put it in reverse some wire shorts. Can you look for loose connectors on top or sides and under the transmission? Maybe any wires that look fried or naked or whatever other than normal. Or connectors that are loose and not tight. I had once an issue long time ago with a civic's reverse light sensor shorting out. Just a thought. By the way, safety first. Don't do anything stupid and put yourself in any kind of danger. I would recommend to disconnect the battery if you start touching wires to see how they feel and also if you get under the car to look for loose wires, please support the car safely on good condition jack stands.
edit: also you may want to check the front engine mount vacuum hose line to see if it is good condition with no cracks, from the mount itself all the way to the back of the intake manifold where it gets its vacuum from. Maybe, just maybe, when you put the car in reverse the hose loosens up somewhere along the way or rubs something and causes an intake vacuum leak.
Old Nov 4, 2012 | 08:03 PM
Bmoreaj's Avatar
Thanks after your advice I played around with it the hose on the intake now I can back again because it had got worst I couldnt even get out my parking spot....it's dark out and I'm no mechanic so I'm going have someone look at it before I go to the dealer, I'm hoping its a small thing and not nothing major.
Old Nov 5, 2012 | 03:44 PM
Bmoreaj's Avatar
I believe it's my mass air flow sensor I'm about to do some more checking...
baelim
May 10, 2018 09:53 AM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
STC
Sep 23, 2015 04:36 PM
