Remove A-Pillar without deploying air bag..??
Old Jan 5, 2015 | 10:24 PM
Cooldude01's Avatar
Hello everyone,
Has anyone tried to remove the A-pillar "successfully"?
I'm thinking about trying that but the manual mentioned about the chance of deploying the airbag..
I don't want to cause any unnecessary repair cost .
Any helps are appreciated..
Old Jan 5, 2015 | 11:12 PM
csmeance's Avatar
Originally Posted by Cooldude01
Hello everyone,
Undo the battery and wait 30 minutes. Make sure you have the radio codes, this removes power to the car and the airbags. Also I believe all you have to do is unclip the pillar and pull outward.
Old Jan 6, 2015 | 08:51 AM
CerberusKy's Avatar
I removed my A-pillar without any issues. Just take your time and don't force anything and it should be fine.
Old Jan 6, 2015 | 09:21 AM
that little square that says ABS is infact a clip.
once you pry that ABS clip off the a-pillar comes right off.
No chance of air bag deployment at all.
if you're really scared, un-hook the battery like csmeance suggested
Old Jan 6, 2015 | 07:58 PM
Cooldude01's Avatar
This is what really concerns me...
The manual uses a rubber mallet to hit the SRS logo in order to remove the screw. I haven't thought about un-hook the battery terminal. I will do that just to be safe.
Thanks guys.
Old Jan 7, 2015 | 06:52 AM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
I had to replace mine due to a grease stain that was impossible to remove with cleaners etc. If you are not planning on keeping the pillar you can pry the clip off, essentially deforming the material of the pillar, if too unlucky. The safe way of not deforming it is to bang that "ABS" hard enough to brake the clip edge behind (where the edge of the F arrow is). The replacement clip is: 91561-TA0-A11, costs around $3.
By the way, the triggers of the airbag are nowhere near that area and the airbag is smart enough not to be deployed unless it receives a direct command from the computer, at a specific voltage. There are enough stupid-proof mechanisms built into these things for safety. But go ahead and remove the "-" battery terminal just to feel safe.
Old Jan 7, 2015 | 08:02 AM
Dont use a rubber mallet, then.
it's just a clip.
you can push it back in with your fingers.
Old Jan 7, 2015 | 07:53 PM
Cooldude01's Avatar
it's just a clip.
The clip is internal, you can't see it so i don't think you have an option to push it back. I believe this is the reason why the manual suggested to gently tap the pillar so the "F" section of the clip will be broken off hence the clip will need to be replace.
I will disconnect the negative terminal just to be safe.
Thanks for the inputs all.
Old Jan 7, 2015 | 09:36 PM
Samba's Avatar
Well. The clip costs $9 + tax here in Canada.
Old Jan 7, 2015 | 10:04 PM
Cooldude01's Avatar
I agree, the design should have some error-proofing mechanisms built into it but looks like the clip replacement is unavoidable.
Old Jan 8, 2015 | 01:20 AM
Edward'TLS's Avatar
6G TLX-S
These clips are specially designed to be used in securing pillar trims on curtain airbag equipped Honda/Acura vehicles, such that when the airbags deploy, the pillar trims will stay in place rather than flying out towards the occupancies inside the vehicle.
As a result, they have to be destroyed, by the rubber mallet, in order to release the pillar trims.
So never reuse any old clip, for the sake of safety reason.
A few bucks is nothing when compared to losing an eye or gaining a permanent gash across the face.
Old Jan 8, 2015 | 04:10 AM
Tonyware's Avatar
I bought a bunch of small parts from DelrayAcura on-line when the Canadian dollar was at par. Total bill came to -20% with shipping and all import duties. To give you an idea, one mud guard in Canada costs around $100. The entire set, all 4 corners, from the US costs $100 !!! The most f*cked up thing is that most of these parts are made right here in Ontario by 3rd party suppliers, shipped duty free to the US for assembling vehicles under the NAFTA agreement and then imported back into Canada with duties/taxes on them.
Yeah, free health care for everyone ! LOL. (don't get me started...)
Old Jan 8, 2015 | 06:19 AM
Ive always removed the ABS square clip with a flat head.
get it underneath the ABS square and pry.
use a towel or cloth to prevent scuffs, tears into interior
and I thought you all were talking about putting the a-pillar back on....
Old Jan 8, 2015 | 06:20 AM
FIYW; the air module is no where near that square
Old Jan 8, 2015 | 08:49 PM
Cooldude01's Avatar
This actually is a good idea to pry the ABS square. It will expose the clip after the square is removed. I'll try this when it gets a little warmer. Too darn cold right now...
peti1212
ILX
22
Jan 5, 2022 05:14 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
