Rattle / Squeak when turn on car 12 AWD
Hey all I just got a 12 Advance SH-AWD I noticed that more than half of the times that I turn on the car, a weird noise comes from the front end. It sounds like chuckle or something from a bird, or a muffled rattle, only way I can describe it.
Has anyone had something like this? Acura did replace the propellor shaft when I first got the car, could they have messed something up?
I get the same sound when I start my '12. I left it as "normal" start up sound with various electrical components going through their start cycle and fluids starting to circulate within. With my previous 03 TL, it made different sound with ABS check sound within a few seconds of starting. As long as the car drives ok with no dummy lights on, good to go.
^^ OMG, it does sound like a bird as you described!! I have a 2012 and never heard that noise....I would have a dealer (or SPCA) check it out.
Thanks for taking the time to post the sound file....it makes such a difference being able to hear it.
Sly, i had this noise too on my 12 advance awd. Mine only makes this noise on the very first startup of the day. It does it when its colder more often too. I hear it make that noise but louder, when i put it in reverse when the idle is high (from the first start). If i wait for the idle to come down and let it warm up, it doesn't do this. I was talking in pm to another member on here that had the same problem/noise. He took it to the dealership at night. He then returned the next morning to show the tech the noise. They replaced a transmission filter. It stopped making the noise...he also said it doesnt effect or damage the transmission, but is more annoying than anything. I have not brought mine in as it has not gotten worse, plus it doesnt happen as much since its warmer and i let my car idle drop a bit
Here is the other members response:
Cold start gurgle and then all was ok for the rest of the day, no gurgle when hot start....
External transmission filter was replaced under warranty, since then all is good....no annoying cold start gurgles...
Any help with this? The dealership had my car for 3 weeks and replaced the tensioner and drive belt. Said they thought it was fixed but the first day back it still makes the same exact noise. Should I just go to another dealership? They swear there is not transmission filter
I think the trans filter was new in '12. Not sure if it is used in all models.
The dealership guy who spoke to you may not know which TLs have the filter. Check it out on the Acura site.
For anyone else that may be in my case. Here is my email to my dealership with the 2 attachments.
Sir I have done more research. Please see the attached.
This forum thread talks about the 2012 TL having issues with a “gurgling” sound on startup.
https://acurazine.com/forums/showthread.php?t=911134
One person stated "When it goes bad ,it makes an annoying gurgling sound...
I had it replaced under warranty….”
Another person said "Arek, when i first start up my car in the morning (first start when cold), then put it into reverse, it will make this gurgle like water or air bubbles flowing. It does it for about 15 secs then goes away. It will not do it the rest of the day...im in sales, so im starting and stopping my car 10-15 times a day. Is that when you heard that gurgle you are talking about? If so, did it do it after the first cold start?”
A response to this someone said "External transmission fluid filter!!!
That was my exact problem. See my thread below were some other members were nice enough to help me out seeing how dealerships have been having a hard problem diagnosing this issue. There is also a sound cloud clip of the noise.”
Now here is a completely different thread about the same issue. All the people posting have a 2012 TL
https://acurazine.com/forums/4g-tl-problems-fixes-297/need-help-identifying-noise-904002/
Ironically, one poster said this "The dealership has already replaced the alternator belt and the belt tensioner adjuster, also the propeller shaft but that was bc another problem.”
A completely different thread:
https://acurazine.com/forums/4g-tl-problems-fixes-297/weirdest-sound-ive-heard-car-880507/
Different posters have posted similar sound clips:
https://soundcloud.com/kcarr91/car-noise (particularly low, need to really listen)
https://www.dropbox.com/s/ag7k8ffgpr...rd%20Sound.mp3
Here is even a different person with a youtube video, again a 2012 TL
Finally one person said this "Good news... You don't have to live with this noise any longer. My 2012 TL SH-AWD made the same exact noise, every morning for the first few minutes after starting it up. And the colder the weather, the worse it was.
I took my car to the dealer a few days ago and they diagnosed it as a failed transmission filter. The transmission filter is external to the transmission, it's cylindrical in shape and apparently has a baffle inside of it that was broken, causing the noise. When they called me and told me this I was skeptical but they replaced it and the strange cold startup noise is 100% gone!"
This poster included his Pohanka Acura receipt to show the transmission filter that I was told by you all doesn’t exist. Please see attached.
Please also see attached diagram of where the transmission filter is.
I'd print out the attached service bulletin in the previous posts by me and if they give you an issue, then copy my email to the manager with the sound clips.
OR you could let them do it on their own. I did get 2 belts changed for free so whatever haha
handsom-hustla
Nov 13, 2015 05:04 PM
2012wagon
Sep 29, 2015 04:21 PM
