Noise from airbag cover
Old 11-20-2015, 11:40 PM
caseman22's Avatar
So I have been hearing this vibration noise coming from the steering column. I finally found it. It is coming from the air bag cover in the steering wheel. Has anyone had this problem? I haven't taken anything apart yet. I'm a little afraid that doing so may set off the air bag. Any thoughts?
Old 11-21-2015, 05:48 AM
dainmezron's Avatar
Does the noise sound like a faint ticking from a Geiger counter, and even perhaps changes/stops when you are not allowing weight of your arms to pull downward on the steering wheel? I have some kind of sound like that, haven't nailed the cause down yet. And yes, taking apart the cover should probably be left to the professionals.
Old 11-21-2015, 11:17 PM
caseman22's Avatar
No. It sounds like plastic parts vibrating against each other and it right under the airbag cover. If I put my hand on it the noise stops.
Old 11-23-2015, 08:33 PM
Resident Dingo
TheDingo's Avatar
You can pull the airbag out pretty easily. In some other Acuras, the cover on the airbag is a part of the airbag (it cannot be removed). So if something is loose in there you might just want to replace it. Especially if that loose object could become a projectile in a car crash.
cprime
06-19-2016 02:18 AM
Hscam
4G TL Problems & Fixes
11-25-2015 08:58 AM
cfli1688c1
11-20-2015 08:03 PM
LaJay007
11-20-2015 01:36 PM
JWvegas
1G RDX (2007-2012)
11-20-2015 08:46 AM
Quick Reply: Noise from airbag cover
