Need help removing fuse panel
Old Dec 17, 2017 | 02:58 PM
sunshne078's Avatar
Hey! I’ve got a ‘Check VSA System’ light on and want to check the fuses in the fuse box under the hood, but I cannot pry it out. I removed the screw that appeared to be anchoring it, but what’s the trick to prying it out? I feel like an idiot.
Old Dec 17, 2017 | 04:55 PM
sunshne078's Avatar
I should clarify that I’ve got the fuse box open and I’m looking to access the bar of fuses dealing with VSA and ABS. I’ve chipped the plastic trying to get it to pop out.
Old Dec 25, 2017 | 01:10 PM
grandlaker's Avatar
Just popped mine out this morning. On right side there is a small clip you need to disengage and then I used pair of pliers and pulled straight up and it popped right out.
TheyGotMawty
Feb 20, 2017 05:59 PM
know610
Jan 21, 2017 05:21 PM
rick sambora
May 11, 2013 05:52 PM
kris10950
Oct 7, 2008 05:02 PM
Panda_TSX
1G TSX Problems & Fixes
Jan 2, 2006 03:52 PM
