Need Help: Fog Lights
Old Sep 20, 2013 | 08:11 PM
Packagingpro's Avatar
I have had my HID Fogs for 2 years. Yesterday, the passenger side went out. I am not sure if it was the bulb or ballast. I decided to put new H11 Halogens and get rid of the HID Kit. It turns out the H11 isn't working. I took my time not to touch the glass and used gloves as well. Tried 2 brand new sylvania bulbs. The Driver Side HID still works fine.
Is it possible the wires are fried? It was a 35 watt kit. Is there a separate fuse for the driver side?
Old Sep 20, 2013 | 08:50 PM
potmilkz's Avatar
check if there is power by using a voltage tester..
i believe there is a fuse, check both sides of the kick panel.
Old Sep 20, 2013 | 09:06 PM
Potz, if one fog light is working, would that rule out the fuse? Is it possible that there is a separate fuse for the passenger and driver side ?
Old Sep 20, 2013 | 10:04 PM
si1point6's Avatar
You guessed correctly - There is a separate fuze for each fog light. You can find the passenger-side fog light fuze in the passenger-side fuze box. Move the passenger seat back and take a look at the passenger kick panel under the glove box and to the right. The passenger-side fog light fuze is in fuze position #3, and it is a 10A.
Old Sep 21, 2013 | 07:00 AM
It was the fuse! My HID's are blowing the fuse, switching back to H11.
Thanks for the help!
Old Sep 21, 2013 | 08:35 AM
si1point6's Avatar
You are welcome - I'm glad to hear things worked out
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
