HID for DRL not working
Old Sep 19, 2013 | 04:07 PM
elietania's Avatar
I bought 2 kit of hid one for my drl and for the fog light.
the drl bulb just flicker fast do you guys know why?
and for the fog light I didn't try it yet is it gonna be the same problem? thank you
Old Sep 19, 2013 | 06:02 PM
elietania's Avatar
I found the answer thank you...
there is a special harness to install a hid kit in drl....
Old Sep 19, 2013 | 06:32 PM
potmilkz's Avatar
the problem is that you do not put hid as drl...
hid kits are made to run at full power.. drl run at little less then half, thus will cause electrical problems through out your car in the long run..
led or halogens as drl, and fogs can be hid..
you should not run hid bulbs as drl, im sure everyone here can agree with me.
Old Sep 19, 2013 | 06:37 PM
elietania's Avatar
Im gonna connect the power to the battery
Old Sep 19, 2013 | 06:45 PM
Mr Marco's Avatar
HiD for the brights? Pull the fuse on the DRL.
Old Sep 20, 2013 | 09:11 AM
elietania's Avatar
if i do that theres gonna be a drl light in the dash board... just gonna get the harness to connected on the battery
Old Sep 20, 2013 | 09:27 AM
ucf_bronco's Avatar
No, pulling the DRL fuse does not result in a light in the dash.
Old Sep 20, 2013 | 10:27 AM
elietania's Avatar
oh thats cool but i will get a ticket here in canada its a law to have drl.... so maybe with the harness that takes the power from the battery for the hid kit i will not loose my drl! and i went with hid for drl because its the same bulb for high beam and the led bulb are not strong enough to be used like high beam if im not mistaking!
Old Sep 20, 2013 | 10:57 AM
Mr Marco's Avatar
I forgot you have those laws. You will like the HiD once you instal the harness.
Old Sep 20, 2013 | 11:02 AM
jim_c's Avatar
Check out the laws in your province. There is some misunderstanding about the DRL requirement since part of the regulations are federal and most of the laws the police enforce on the roads are provincial. I am not saying you don't need them (they are a proven fact for increased safety) but there are plenty of newer cars running around in Ont. without them, with no apparent hassles.
Old Sep 20, 2013 | 11:20 AM
potmilkz's Avatar
you are one of those people that i would hate to be infront of..
Old Sep 20, 2013 | 03:10 PM
Jackieee_TL's Avatar
I used a HID harness relay on my LED drl's before, but the problem is the relay on the harness. It would still not turn on since the stock high/DRL harness is only putting out around 6 volts, so that would not be enough to trigger/activate the relay. It would work if you have the high beams on since it sends 12+ volts.
Also expect to be flashed a lot from oncoming traffic. I know I would do that since it irritates the shit out of me.
Old Sep 20, 2013 | 04:48 PM
Mr Marco's Avatar
Again...
"What is behind, non e importante." (What is behind is not important) -Enzo Ferrari, when asked why it was so hard to see out the back of his latest creation, the F-40.
Old Sep 20, 2013 | 09:39 PM
elietania's Avatar
the harness you got wasn't connected to the battery?
flashed? during the day I don't think so...
Old Sep 20, 2013 | 11:41 PM
It's a HID harness... Where else would it be connected to? You buy the harness to get power from the battery vs the stock bulb harness/connectors. Try it out and see. In my case, it didn't work since the relay wasn't getting enough volts to trigger from the drl mode.
Old Sep 21, 2013 | 12:02 PM
elietania's Avatar
We never know that's why I asked you to make sure we are talking about the same thing! anyway I contacted ddm tuning support and I will loose the drl with that the bulb will be always on they said...
just gonna make my life easier and go with the led bulb
thank you!
sockr1
Oct 1, 2015 01:31 AM
acurajj
Sep 19, 2015 03:47 PM
JnC
Sep 11, 2015 06:06 AM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
