Liquid Gurgling Sound When Starting Engine
Old Apr 22, 2014 | 09:04 PM
TL14's Avatar
I here a gurgling sound when I fire up my TL after it's been sitting for a while. Any ideas of what this is? Is it normal?
Old Apr 22, 2014 | 09:25 PM
TL14's Avatar
For clarification... This sound is heard after initial start up...while idling.
Old Apr 22, 2014 | 09:26 PM
012TL-GLM's Avatar
I Have The Same Issue, Been Happening For A While On My 12 Tl, I ThinkSomeone Else Here Mentioned The Issue Previously And Found Out It Was The Transmission Cooler. I Plan To Have It Looked At eventually
Old Apr 23, 2014 | 08:27 AM
kcarr91's Avatar
Yep it is the external transmission fluid filter. See my thread when i had the same problem.
https://acurazine.com/forums/4g-tl-problems-fixes-297/need-help-identifying-noise-904002/
and the original thread
https://acurazine.com/forums/4g-tl-problems-fixes-297/weirdest-sound-ive-heard-car-880507/
Old Apr 23, 2014 | 08:42 AM
cagilber's Avatar
I've just started noticing the same sound on my '12 TL over the last couple weeks.
Old Apr 23, 2014 | 09:50 AM
a35tl's Avatar
My '12 does the exact same thing. Typically, it only happens first thing in the morning. It lasts a couple of seconds and then it's over.
Does anyone know how long this repair would take? Also, what are the risks of not getting it repaired? I will have mine fixed but just curious what would happen if I did nothing. Thankfully, I'm still under warranty.
Old Apr 25, 2014 | 09:04 AM
Reorge's Avatar
I changed my external trans filter two weeks ago when I reached 30k miles. I was surprised how “dirty” the fluid was when I drained the old filter. I haven’t cut it open yet. It’s located under the battery tray. I had difficulty getting the clamps off until I borrowed my Dad’s long reach dual pivot (wide opening jaw) pliers.
Based on this gurgling issue and the filter fluid condition I plan to change it every 30K miles for my piece of mind.
Filter part number is 25430-PLR-003 (~$18 with 30% off list)
Old Oct 14, 2016 | 07:05 AM
soniczoom5's Avatar
my '14 has been doing this for a few months now; taking it into the dealer on Wed. to get it looked at; thanks for the info everyone
Old Oct 14, 2016 | 08:46 AM
randyt15's Avatar
9th Gear
Yeap it's the Tranny filter (there's a TSB) for this .... it only happends in the mornings in cooler weather. they (dealer) said it was'nt covered under warrenty so they had to check with ACURA and they told them to fix it. it was the second time I had the car in for them to hear the noise (dealers don't want to fix anything...just do expensive oil changes)
Old Oct 14, 2016 | 07:00 PM
Reorge's Avatar
TSB 14-049
Hyperlink: http://www.urvi.net/forumfiles/SB/B14-049.PDF
Feb 25, 2020 09:57 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
Tsov Tom
Sep 6, 2015 07:56 AM
