LED strip installation
Old Jul 14, 2009 | 05:19 PM
fusiongt's Avatar
ok. I just bought pair of led strips for the car. BUT can any1 guide me how to hook it up???? what I really want is... light it up with only daytime running lamp.
Old Jul 21, 2009 | 08:53 AM
BLACKURA_NY's Avatar
I have car ADD
You'll need to bake the headlights in the oven to open them up, install the strips... then wire them... the DRL uses very lower power consumption, so the LEDs may not light up 100% on the DRL feed
maybe independent switch, or power then from the parking lights IMO
Old Nov 4, 2010 | 09:24 PM
Beeper27's Avatar
I got my LED's hooked up to the iginition, so they are on when I turn the car on, and I just pulled the fuse for the DRL's to turn off the factory ones. I also added another fuse to the wiring to the iginition for the LED's, just to be safe.
Old Nov 4, 2010 | 09:32 PM
Steven Bell's Avatar
Fusion, I've done this mod-it's awesome. You do need to open up the headlights (by baking them for 20 minutes at 200 degrees). I wired them so they are always on (with the DRL's and headlights). There is a green wire against the firewall that goes to the windshield wipers that is "hot", which allows you to have the LED strips on all the time. If you want to see my headlights, look at my Garage to see the details. PM me if you have any questions-I'd be glad to help you.
Old Nov 8, 2010 | 02:57 AM
AckTL05's Avatar
Former Sponsor
If you need help with installing them, I do custom headlight work.
other then that, I would hook them up to a separate switch so you can turn them off or on at any point.
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
Iakonafuji
Sep 21, 2015 02:39 PM
Greengecko
Sep 16, 2015 08:19 PM
ghuns
Sep 16, 2015 04:26 PM
