Keyfob battery running low
Old Sep 26, 2015 | 06:57 PM
SilverJ's Avatar
Hi All:
I am getting a flashing indicator on my TL that its time to replace my Keyfob battery. I have a 2012 Tech. What happens if the Keyfob dies while I am driving ?
Being its pushbutton I am just wondering.
Also is there a diagram on replacing the battery ? Im pretty sure these are just watch batteries.
thx in advance.
Old Sep 26, 2015 | 07:35 PM
TheMuffinMan's Avatar
It's in the user manual, but if it's low (dead low), you should be able to actually insert the fob into the slot to start the car and be good. If the fob dies while the car is currently driving though, the vehicle does not turn off, you just would be unable to restart the car if you stop it.
In terms of the actual replacement -
Old Sep 26, 2015 | 07:37 PM
dainmezron's Avatar
Originally Posted by SilverJ
Hi All:
thx in advance.
To replace the CR 2032 key remote battery.........Replace the battery if necessary.
To replace the battery:
Replace the old battery with a new battery. Place the battery so the side is facing up. Snap the two halves of the remote case back together. Remove the built-in key(seepage ). Place a cloth on the edge to prevent scratches, then remove the upper half by carefully prying on the edge with a coin.
And put the keyless remote into the keyless access remote slot while driving if the battery is weak. You can take it out when you have turned off the engine.
Old Sep 27, 2015 | 08:31 AM
SilverJ's Avatar
Thanks guys!
Old Sep 27, 2015 | 10:16 AM
ITSJESTER's Avatar
An easier way I found was to remove the built in key and use a coin to pry the two halves apart. A penny fits in the spot where the key slides in perfectly. Just twist the penny so the two haves split. Then be gentle and pull the two pieces apart with your fingers.
This also avoids potentially scratching the cheap chrome finish on the fob!
Old Sep 27, 2015 | 11:37 AM
a35tl's Avatar
Looks like I'll be replacing my battery too. My light just came on yesterday indicating that the battery was low. Coincidentally, I placed my finger in the key fob slot on the dash and the warning lights turned off. I'll keep doing that until I find time to go by the store to pick up a new battery in the next day or two.
Old Sep 27, 2015 | 12:01 PM
ITSJESTER's Avatar
Just an FYI, the battery is a CR 2032... Not sure if the video mentions that, I just skipped through it
Old Sep 28, 2015 | 08:53 AM
SilverJ's Avatar
It's actually the hole NEXT to where the key slides in. Thank you though. This makes it even easier to take apart.
Old Sep 28, 2015 | 09:04 AM
ITSJESTER's Avatar
You are absolutely correct. I wasnt looking at the fob when I wrote it...
Old Sep 30, 2015 | 03:57 PM
ganju420's Avatar
Based on the tips on this thread, I replaced battery in one of the remote in my 2012 TL. It take CR20132 battery and took my less then 2 minutes. Thanks Guys!
Old Oct 9, 2015 | 02:39 PM
SilverJ's Avatar
Just an FYI guys, never have the dealer replace this for you. They want 5 dollars to replace it and that gives you ONE battery. You can buy 5 batteries for 5 or 6 dollars and replace it yourself, which is what I did.
Old Oct 9, 2015 | 02:48 PM
ITSJESTER's Avatar
agreed, I got a six pack of them on sale at target for just under $5.00
Old Oct 12, 2015 | 02:22 PM
DoubleF's Avatar
A dealership sales guy tried to tell me to charge my key fob in the key fob slot. I don't go there any more. I even reported him to the manager. It's one thing to be sleazy and bend the truth. But this guy...
Old Oct 12, 2015 | 02:31 PM
SilverJ's Avatar
I don't know if that would be considered sleazy. Just dumb.
Old Oct 13, 2015 | 09:31 AM
DoubleF's Avatar
Exactly. There are likely those who would actually listen to this guy just so he could save 5 minutes and a dollar.
Old Oct 13, 2015 | 05:14 PM
ITSJESTER's Avatar
Would be kinda cool if this actually worked
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
Phambam12
Sep 6, 2015 06:57 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
