Just replaced the Clutch and Flywheel on 13 TL reverse lights wont come on.
I love the Aasco flywheel which was a $h!t ton lighter than OEM and the car runs beautifully. Exedy clutch feels OEM though the pedal is softer than I like but all in all a great replacement.
One problem however, in reverse gear lights wont come on, mirror will not tilt and reverse camera will not turn on.
The installation was performed by a certified (NON ACURA) auto mechanic and I plan to have him take a look but if you guys could present ideas for a quick fix I could do myself.........
I would assume its a unconnected electrical harness or sensor or something but cant find any idea where to look on line.
It might be item 17 (Switch Assy, Back Light) causing the problems you describe. (Unplugged, broken wire/plug/switch, etc.)
https://www.acurapartsforless.com/v-...nsmission-case
Craig Silver (05-17-2019)
Bars
05-01-2018 11:50 PM
A418t81
02-15-2012 02:46 PM
CivicB18B1
07-23-2011 10:47 PM
JayT
01-29-2009 08:58 PM
