Intermittent squeak post pad change
Old Dec 26, 2018 | 09:33 AM
Jon Weber's Avatar
Hi All,
I have a 2012 TL and I changed its rear pads a few weeks ago. I didn't notice anything right away, but over the last few weeks, I hear a squeal coming from the driver rear wheel. I thought it was just the new pads, but noticed that it didn't change one bit as I applied brakes or engaged ebrake. Took wheel off and the pads are touching the rotor and there there is slight warp in the rotor (I didn't change those) but again.....the noise is still there when braking. It's not constant and it speeds up and slows down with the speed. I can only hear it around 5 MPH. At highway speeds I hear a thump that I thought was a tire issue (same wheel) because that, too, synched with speed and not RPM. I thought, too, that it might be ebrake shoes....but, again....it doesn't stop when I drag the ebrake. Puzzling. Any ideas? I searched the forums before I posted, but couldn't find anything. I apologize if I missed something. Any help would be appreciated.
Thanks! JW
Old Dec 26, 2018 | 02:30 PM
Jon Weber's Avatar
Annoying Rattle from Passenger Seat -UPDATE
pulled the wheel and hub off. Parking brake assembly looked crooked. Thought some WD 40 and re-positioning would do the trick. But, same thing. I did notice, though that the noise was very pronounced when turning hard left going just a mile or 2 an hour. Turning right....no sound. Again, noise is coming from driver side rear. Any ideas? Wheel bearing?
Old Dec 26, 2018 | 03:41 PM
your parking brake may need adjustment
Old Dec 26, 2018 | 10:47 PM
Jon Weber's Avatar
thoiboi,
You're right. I adjusted it and no more noise. Thanks!
Old May 10, 2019 | 04:15 PM
ImStillSOLO's Avatar
Was it a constant squeal?
I have an 09 TL awd and put stoptech drilled and slotted rotors and posiquiet pads on it. The front passenger wheel squeals and i don’t know what else to do with this. It’s making me go crazy
WDPTL
May 1, 2013 05:48 PM
I hate cars
40
Nov 24, 2010 09:39 AM
becker800
May 8, 2007 02:35 PM
Austin519
Dec 20, 2001 02:44 PM
Shoofin
Jan 15, 2001 01:12 AM
