How to turn off beeping noise when exiting the 4th gen. TL with engine on???
Old 05-17-2011, 01:51 PM
Rmanoo123's Avatar
Hey I'm not sure if anyone has the same problem. My 2010 TL makes several loud beeping noises when opening the door and exiting the car with the key fob while the engine is on. Any suggestions on how to turn off this feature??? A real pain the ass when coming home late and moving around the cars in the driveway lol.
Old 05-17-2011, 01:58 PM
potmilkz's Avatar
Received 1,021 Likes on 793 Posts
i dont think you can change that..
Old 05-17-2011, 02:23 PM
Treblig's Avatar
IIRC, if the door is partially closed then there is no beeping sound.
Old 05-18-2011, 11:38 AM
maddogtheta's Avatar
^ If you leave the door open there shouldn't be a beep. The beep is to warn you that you are leaving the car while it is still running and if you closed the door you may have forgotten to shut the car off. I don't think there's a way to disable this safety feature
Old 05-18-2011, 12:05 PM
Mr Marco's Avatar
Another AZ member posted that this "beep" could be turned down (so you don't wake the neighbors when you get out of the car to shut the garage door at 6AM). I think they said you could find it in the MID under security settings, or something to that effect. I've been too lazy to look for it. Do a search.
Old 07-01-2011, 10:51 PM
4th Gear
gmancbp's Avatar
It is listed in the owners manual to turn it down and you can turn off the system with the switch in the glove box.
Old 07-08-2011, 10:42 AM
2010_Type_SH's Avatar
All cars with push button starts have this feature. The car trying to warn you that you are leaving the car running with no key fobs inside.
This is a safety feature since the car does not need a physical key in the ignition to stay on. I guess it's your choice if you want it on or off. I personally like it one.
rockyboy
12-06-2022 02:29 PM
02-25-2020 09:57 AM
iCrap
09-11-2015 06:21 PM
Phambam12
09-06-2015 06:57 PM
Quick Reply: How to turn off beeping noise when exiting the 4th gen. TL with engine on???
