Hazards and turn signals just cut out!!
So like it sat was driving my 2013 TL went to turn right signal didn’t work then tried the left like 45 seconds later it worked. Pulled over then nothing worked same with the hazards. I’m thinking it’s the relay but can not find any legit information on where it’s at. First was told it was under the steering wheel. Looked under there and really don’t see anything. I guess it’s theee on an MDX. Anyways if anyone could help that world be fantastic!!!!
It looks like water is getting into the driver's fuse box and it's going crazy. You need to get there and check all the connectors for waterlogging. Is the Sunroof leaking? It uses MOSFETs instead of relays.
TLTrance
May 31, 2007 09:48 PM
