Glove box light
Old Mar 27, 2015 | 11:35 AM
tommh1024's Avatar
Glove box light
Does anybody know how to get to the light in the glove box?
Old Mar 28, 2015 | 05:51 PM
TheMuffinMan's Avatar
Fair warning, you risk breaking the assembly and have to buy a replacement, I broke both the glovebox and center console one when replacing with LEDs.
Take a thin knife/screwdriver blade and you should see a slight indentation on the white/clear lense facing the back of the car (so right in front of you). Slide the blade between the lense and the side of the glovebox and slowly pry it out. There are two metal prong/clips at the top and bottom of the little light assembly.
To remove the assembly and expose the bulb just twist the whole black assembly ~90 degrees and it'll come right off. There should be enough slack in the wiring harness to pull it out into the glovebox.
oyayjoe
Jan 1, 2019 10:17 PM
sockr1
Oct 1, 2015 01:31 AM
Sep 14, 2015 10:09 PM
oyayjoe
Sep 12, 2015 04:40 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
