Engine Swap '10 to '12 J35Z6
Old Jun 30, 2020 | 04:36 PM
cajunbug's Avatar
Background-
Bought '10 TL Tech from an auction last year. The car flooded and the engine was hydro-locked. All interior features/accessories work fine. From Nav to seats and the IP does not have any MILs. Also, slight flood smell (will replace carpet) but it's clean and no rust so I think it was minor.
What's been done:
Not knowing any better, I bought a 2012 3.5 I noticed the harness was a little different so I used the original 2010 harness.
Replaced timing belt and water pump.
No fuel- replaced the sending unit
No BCM communication from ECU - replaced ECU
-- Rewrote the VIN and reset the immo since the green key flashed (had to but a capable scanner since the dealer wanted $1,150 for the ECU plus $300+ labor with no guarantees)
Currently:
Still get the BCM code but I was not able to find a BCM module (Using DYIAllData)
The car just cranks but does not start.
I just ordered a 2012 ECU ($115 from salvage yard). Should be here in a few days.
What I'm planning:
The plan is to replace the wiring harness back to the 2012 and use the 2012 ECU and reprogram my keys to it.
My question (HELP!!):
Has anyone been able to replace the 2010 J35 with a 2012 J35 successfully? If so, please share your insight.
Old Jun 30, 2020 | 06:21 PM
interesting...it's the same motor.
silly question; is the ECU fuse under the hood blown?
Old Jun 30, 2020 | 07:56 PM
cajunbug's Avatar
Not a silly question. It's fine.
Old Jul 1, 2020 | 12:10 PM
cuz one day; I was messing with the car....and I had gotten the green key flash...(immobilizer)...had a friend use the HDS and Honda software to reset the immobilizer, however my car wouldnt start.
after a few days of troubleshooting, my ECU fuse was blown. preventing the car from starting.
Old Jul 1, 2020 | 01:13 PM
cajunbug's Avatar
You got my hopes up but I just checked all of the fuses under the hood and they're all good.
I was reading/comparing parts between the 2010 and the 2012. I saw that the torque converter was different. So, I saw that the transmissions are different (5 spd and 6 spd.) It may be that after it starts, I'll have to change the transmission also. I checked and can get a used one for about $300. The engine wiring harness seems to have all of the trainny wires/plugs so that should be fine (I hope).
In the next couple of days, I'll remove the '10 wiring harness and compare each plug to the '12. I'll note the any color differences or wire locations just so I'll know what components may be different and may help if the car does not run with the '12 computer. So far, the only part that I've seen is different is the flex plate,torque converter and trainny.
justnspace, I appreciate your help. Wish I could share some of this fun :-)
Old Jul 2, 2020 | 12:15 PM
cajunbug's Avatar
Post
I'm going back to the basics. After comparing the pinout for the 2010 and the 20112, the differences are very minor and none that should keen the car from running.
The differences noted from 2010 point of view:
Connector A: Pin #44
Connector B: Pins #43 and #44 on 2012 relate to trainny
Connector C: Pin #9 on '10 goes to solenoid C, '12 goes to solenoid D
Pin #23, N/A on '10, O2 rear bank 2 on '12
Pin #36 N/A on '10, O2 rear bank 1 on '12
Pin #31 N/A on '10, 6th clutch on '12
Pin #35 N/A on '10, OPPL line pressure
Any suggestions are welcomed!!
I'm attaching the pdf's for both years in case anyone else needs the info.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 2, 2020 | 12:19 PM
cajunbug's Avatar
Post
I had to do two uploads.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 2, 2020 | 12:48 PM
cajunbug's Avatar
Post
2012 TL FWD pinout
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 2, 2020 | 03:46 PM
Edward'TLS's Avatar
6G TLX-S
Likely that the immobilizer is preventing the car from starting.
suprachica79
Jul 9, 2020 10:24 PM
Luckay Muh Fluffin Charmz
Jun 18, 2018 01:41 PM
feuss2
Apr 8, 2008 06:09 PM
Cornflake
1G TL (1996-1998)
18
May 9, 2005 08:34 PM
vtecpowersumo
Sep 20, 2002 12:05 AM
