did something stupid!
Old May 30, 2010 | 08:43 PM
FallenTSX's Avatar
okay, so I was just checking the air filter element and took off the box and what looks like some type of sensor. Looked good, so i put the box back on and left it. Hours later, I go to my car to go somewhere and tried to start it, STALLED OUT!! I was like, uhm. tried it one more time, same thing.
So, I recheck everything in the air filter to make sure I put everything back together (since thats what i was working on before the car stopped working) and found that i forgot to put the sensor clip back on. Started it up and started fine, but now has warning lights and sounds like NASA's command center.
It says that, Check SH-AWD, Hill Start, Emissions, and VSA. After clicking all the messages, I turned off the car and waited a little bit and restarted. Started up fine, but still have the Check Hill Start, Emissions, and VSA. SH-AWD signal turned off.
Now, is there a way to turn all of this off or do I need to bring it into a dealer? Thanks for the help!
2010 TL SH-AWD 6-speed
-DeL
Old May 30, 2010 | 08:45 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Take it back to the stealer to clear the codes. That's what I'd do.
Old May 31, 2010 | 10:06 AM
CCBBUUMM's Avatar
Sometimes pulling the battery cable off will clear the computer too.
Old Jun 2, 2010 | 02:36 PM
KaMLuNg's Avatar
disco the negative battery cable for like a min... it should clear the codes...
Old Jun 18, 2010 | 09:34 PM
fsttyms1's Avatar
Does the 4th gen have a clock backup fuse like the 2nd gen? If it does pull that for a min and see if it clears the codes, that way you wont have to reset anything from disconnecting the battery
knight rider
Mar 4, 2016 08:59 AM
MikeJM310
Sep 24, 2015 07:24 PM
kocyk123
Sep 22, 2015 11:12 PM
