Dhow to delete diagnostic info messages
Old Aug 10, 2015 | 05:48 AM
kar90z's Avatar
On my 2010 TL sh-awd,Keyless access system ,tire pressure minister and daytime running lights came on after car was parked and battery died for a week plus, called dealer said the keyless access system need to fixed might be broken but everything works fine no problems . Tpms works fine and so does drl 's . Frustrating 😔 2
Old Aug 10, 2015 | 02:20 PM
arpypat's Avatar
Not sure if the dealer needs to reset anything to get the keyless access system to work.
I don't know how to delete diagnostic info messages, but it may be the same as deleting the A12/B12 service messages:
- Turn you car into accessory (or ON.. not 100% sure if it makes a difference)
- Use the arrows on the steering wheel to scroll to until you get to the tire pressure screen in the MID (in the gauge cluster)
- Hold the RESET button between the arrows for ~10 seconds
This is how I reset the A12 service message. There was also a message that popped up on my navi screen. This one went away by going into the menu and reading the message.
Hope this helps
Old Aug 10, 2015 | 04:36 PM
kar90z's Avatar
Hope this helps
Thanks a lot gonna try that as soon as I get out of work
Old Sep 2, 2015 | 05:23 PM
jim_c's Avatar
tire pressure minister?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
hashbrown
Sep 29, 2015 12:13 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
