Clutch fluid
Old Jun 21, 2013 | 05:51 PM
PeterPort's Avatar
Clutch fluid
Wondering if anyone here has ever flushed and bled the clutch hydraulics and how hard it is to do.
Old Jun 21, 2013 | 06:59 PM
jim_c's Avatar
Why would you want to do that?
Old Jun 22, 2013 | 11:14 AM
Little Gator's Avatar
Flushed and bled my clutch a year ago. It has bleed nipple just like the brake calipers. It is a little hard to reach, and I found it hard to tighten it once done so it would not leak. It was trial and error for me to not tighten it too much and end up stripping the nipple, and tightening it enough to get it to seal completely. I used a dry, clean napkin to wipe it to check for wet spots on the napkin.
DO NOT actuate the clutch pedal all the way to the floor when trying to pump/flush fluid thru the clutch. This will run the cylinder too far and risk damaging the inside seal.
Be sure to place protective rags on the frame members under actuator cylinder & nipple to keep the fluid from dripping onto the frame members below.
Old Jun 23, 2013 | 08:34 AM
jim_c's Avatar
Again, not meaning to be argumentative, but why would you do that? Original poster has a '12 TL. The only reason to bleed the clutch fluid is if there was some leak or a cylinder - master cyl. or slave cyl. had to be replaced. But that would be done by a dealer under warranty. (?) There is no reason to bleed brake lines or clutch fluid, just for the heck of it, on a regular car that is not used on a racetrack.
Old Jun 23, 2013 | 08:49 AM
PeterPort's Avatar
I know from experience with my other cars that periodic replacement of brake and clutch fluid means better response. In my old Saab, the clutch and brake shared a common reservoir. Flushing the brake lines periodically gave me a higher engagement point and much smoother clutch operation. If it is something that can be done easily, I would like to stay on top of it. I do my own oil changes and plan to keep the car for many miles.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
LeVeL
Oct 18, 2015 04:19 PM
