Climate Control Recirculate not working
Old Nov 7, 2018 | 10:28 AM
RKEnnis's Avatar
Hi,
I've got an '09 Acura TL, and I think that my climate control recirculate control isn't working. The light turns on and off, but the fan sound and air flow does NOT change when actuating the button, and I don't hear any door movement. (If I listen below the dash, I do hear a VERY faint sound like a small motor running for a second or so after pushing the button).
Am I correct in thinking that I should hear a sound difference in the air flow with recirc. on vs off? Can y'all hear the door moving?
Has anyone else had and fixed this issue? I know that on some of the earlier models this was a common issue, but I haven't seen it on the 4th gen. models.
Thanks in advance for any suggestions, I hope to pull the dash apart tomorrow...
Old Nov 7, 2018 | 11:17 AM
dregsfan's Avatar
I do notice a slight increase in air flow when using recirculate. Though a door must be moving when switching to or from recirculate, I don't really hear any sound when it does.
Old Nov 7, 2018 | 04:21 PM
Reorge's Avatar
Cannot hear door on mine
Old Nov 7, 2018 | 04:39 PM
What mode is your system on when trying to use recirc?
Old Nov 7, 2018 | 04:54 PM
losiglow's Avatar
Easy test. Get behind a diesel truck at a stop light with the recirculate on and see if you smell diesel after 10 seconds of having the fan on high. If not, it's working.
Old Nov 8, 2018 | 11:21 AM
RKEnnis's Avatar
Thanks for the responses! After reading through this, now I'm not certain I'm actually having an issue. :/
I DO think that I smell outside smells, and pressing recirculate doesn't fix that issue. And I don't hear even a hint of a fan noise change. I've tried it with the climate control in auto mode in both cool and heat modes with no differences.
I did see a procedure for the climate control self test in the maintenance manual, but it didn't show an error. This all started last summer when I felt that the a/c wasn't cooling in the same way that it used to. The air is still cold, but the car won't cool down as fast as it used to. I was trying to troubleshoot that when I noticed the I don't hear or feel any change at all in the fan noise/air flow when pressing the Recirc. button.
I'm not sure where to go from here. I kind of wish I had another Acura in this body style to compare. Hmmm, maybe a trip to the dealer to test drive a used one.. .lol
Old Nov 11, 2018 | 01:22 PM
RKEnnis's Avatar
Ok, another update. I played around more with the climate control in all modes, but with the fan all the way to high. I'm definitely hearing the fan sound change to louder when it's in recirculate mode. So, that seems to be working fine.
I guess i'll have to wait till next summer and see how the A/C cools then.
Thanks again to all who responded. This group is the greatest!!
Billu99tl
1G TL (1996-1998)
Jul 15, 2018 09:37 PM
Lawtyger
Mar 12, 2011 01:54 PM
cd5-obsession
Jul 12, 2008 10:54 PM
jjpark
Feb 16, 2008 12:01 AM
Crazytree
Jul 27, 2003 04:35 PM
