Chirping and squeaking at cold start - belts?
Hi just purchased a 2012 TL with 112k miles. Car was single owner and great condition.
Immediately after purchasing, I did have a mechanic replaced timing belt, water pump, tensioner, pulley. Also replaced the serpentine/accessory belt (don't know if the tensioner for serpentine belt was replaced). The alternator was also replaced.
The car has pretty load chirping and rhythmic squeaking at cold start, which seems belt related. After a minute the noise fades to barely noticeable.
Here's a link to a recording a cold start up: Recording
It doesn't sound like the slapping/knocking that I've heard for timing belt issue.
Did my mechanic screw up the timing belt job? I inspected the serpentine belt and it's tight.
I'm a little suspect of my mechanic at this point so want to be armed with any thoughts or info of what to check before I have him inspect the car again. Appreciate it!!
I'd check first for any leaks that might be causing the issue.
Also, was the accessory belt tensioner and idler also replaced?
