check abs, vsa, SH-AWD and check hill light comes on
Subscribe
Feb 28, 2019 | 12:24 AM
Does anybody know how to fix or reset my check abs, check vsa system, SH-AWD and check hill light? The lights come on every once in awhile and then it goes away and comes back on later. How do i fix this problem? Is the fuse or do i need to clean my tire sensors?
Reply 0
Feb 28, 2019 | 12:20 PM
How old is the car battery ?
Reply 0
Feb 28, 2019 | 12:50 PM
This sounds like a bad battery. Mine did the same thing for a few weeks right before it stopped starting up. Replaced battery and it was good to go.
Reply 1
Jan 19, 2025 | 10:54 AM
I have the same issue. I replaced the fuse, but it didn't make a difference. I live in Canada, and at the moment there is quite a bit of ice on the roads. The ABS definitely isn't working, Does anyone have any other suggestions other than going to an Acura dealer. The 2 dealers near me haven't been the easiest to work with. Thanks in advance
Reply 0
Feb 2, 2025 | 10:24 AM
Quote: I have the same issue. I replaced the fuse, but it didn't make a difference. I live in Canada, and at the moment there is quite a bit of ice on the roads. The ABS definitely isn't working, Does anyone have any other suggestions other than going to an Acura dealer. The 2 dealers near me haven't been the easiest to work with. Thanks in advance
Any suggestions would be appreciated please. The lack of AWD and ABS in a Canadian Winter isn't ideal. Thanks in advance
Reply 0
Feb 2, 2025 | 04:53 PM
get to an auto parts store that does free code scans or another place, they can tell you why the system tripped. Could be as simple as a ripped/broken wire to a wheel speed sensor (one on each wheel of the car) as all those systems use those 4 sensors. If you have the tech/nav version, it should show the codes on the messages in the navi screen.
Reply 0
Feb 14, 2025 | 01:57 PM
Quote: get to an auto parts store that does free code scans or another place, they can tell you why the system tripped. Could be as simple as a ripped/broken wire to a wheel speed sensor (one on each wheel of the car) as all those systems use those 4 sensors. If you have the tech/nav version, it should show the codes on the messages in the navi screen.
Thanks, I got it scanned and it had a code of 81-01 from an after market scanner. Is anyone familiar with this code? thanks
Reply 0
Feb 14, 2025 | 11:25 PM
Google is your friend:
https://www.justanswer.com/honda/d3h...0the%20vehicle.
https://acurazine.com/forums/4g-tl-p...81-1-a-996162/
Reply 0
Subscribe
