Can't unlock doors, trunk and first ignition turn does nothing
Old Mar 28, 2020 | 10:11 PM
RA050325's Avatar
I was removing my 4 channel alpine amp out of my car and when i put everything back together I started having these issues. List of issues below.
1. car wont lock, unlock, trunk won't unlock with key fob or inside the car.
2. When turning the ignition to the first turn, nothing comes on. i mean nothing..can't lock, roll down windows etc.
3. when I turn the ignition to the next position, everything works. windows, trunk, locks.
I've checked the fuses on the passenger, driver side and under the hood. all the fuses are good. I have a bad feeling i fried something. Another thing i knew i should've done but didnt do, i didn't unplug my battery
Old Mar 29, 2020 | 02:43 AM
Edward'TLS's Avatar
6G TLX-S
Check all ground connections, especially the ones you touched, Make sure when you removed the amp, you screw back tight the factory grounding points.
SaltlifeRasta17
Apr 14, 2017 08:51 AM
TAco23
1G CL Problems & Fixes
Dec 11, 2010 05:56 PM
PsychDoc
Jul 16, 2009 10:03 PM
gtboy
Oct 3, 2007 12:54 AM
