Can't disable VSA!
Well no matter how long i hold down the button, my car won's disable the VSA.
it used to work but now that its snowing and i am trying to have some fun it won't turn off. any advice?
I dunno what the safety rationale is for that, but for whatever reason, honda decided that if the TPMS light is on (tpms error, or no sensors, etc), vsa cannot be disabled.
wow.. learn something new everyday.. i did not know that.. weird why they would associate VSA with tire pressure..
^yeah, i didnt believe it at first. Then my tpms went haywire for 6 months (6 mo because my acura stealership's techs could not figure it out for that long).
While i was researching what it could be, i came across that, and so i tried it when my light was on, and surely, VSA wouldnt go off. They eventually found out the issue for my TPMS, they tried to tell me it was because it was "plugged into the mexican tpms plug", but what really happened is somebody had bent a pin somewhere. They come up with the greatest excuses, like blaming my HONDA steelies for TPMS not working... etc.
If you are really stuck in a situation where you DO need to turn off the VSA and your TPMS has gone to the dogs... pull the VSA fuse out. Safety first! Don't fool with this stuff because its gonna byte you. Only if you really have to!
Becasue the winter tires are mandatory here in Quebec , I use a steel wheels for my winter tire and I didn't get the pressure sensors as they are pretty expensive. On the first winter I was wondering why I cannot turn off the VSA and searching here I found out if TPMS is on error state , no possible to disable the VSA which sometimes in winter you wanted off to get off snow plow.
Jamus22
Jun 11, 2023 10:08 AM
joflewbyu2
Oct 8, 2015 11:16 AM
