4G head lamp haze (inside the lens)
Old May 9, 2015 | 12:20 PM
crxb's Avatar
I noticed on my 2009 some hazing appearing not on the outside of the headlamp - but on the inside near the edges of the top and bottom
has anyone else seen this? and how can it be corrected?
Old May 9, 2015 | 01:56 PM
potmilkz's Avatar
it can only be corrected by opening it and wetsanding and clearing the inside again.
from what i know it is caused by LED bulbs. it emits fumes when turned on which causes the inside of the lens to haze. i had the same problem.
Old May 10, 2015 | 02:40 PM
crxb's Avatar
opening it - how does one open the headlamp lens?
Old May 10, 2015 | 08:22 PM
csmeance's Avatar
you have to put it in the oven and bake it for a bit to soften the silicon glue that holds the plastic lens to the housing. If you search for DIY clearing headlight on the 3G TL forum, you'll find tons of DIYs on it. I have no clue if the pictures work but that's how people pull it apart to remove the amber turn signal reflector, etc.
Old May 10, 2015 | 11:44 PM
potmilkz's Avatar
you can google it and see a video if you are interested.
ROWDY621
Sep 30, 2015 03:20 PM
stogie1020
Cameras & Photography
17
Sep 30, 2015 01:34 AM
hashbrown
Sep 29, 2015 12:13 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
