2013 TL SH-AWD Tech Intermittent no start with flashing red security light on dash
Hi Everyone,
Really hoping for some help here because I don't have any service centers or dealerships I think will be able to help much with this one.
I came out to the car after driving it around all day, went to start it and got a momentary (split second) response where everything seemed normal (all dash light, interior lights, etc came on) and then after maybe one or two cranks everything went dark and unresponsive. But I did notice the red security system / immobilizer / anti-theft light was flashing. Here is what I tried in order:
I have a hard time believing its any of the following:
Its almost like the immobilizer is activating and preventing the car from responding... Has anyone ever had any experience with bizarre behavior like this? I have found other threads that have similar stories but no fix was ever identified.
Thanks in advance for even reading through this.
Nika
- Locking and unlocking via the remote. Red button on the remote flashes when pressing buttons. Seemingly normal behavior from the remote, but absolutely no response from the car.
- Locking and unlocking via the power lock button on the driver's door. Nothing.
- Checked both battery terminals. Yanking on it straight upwards; I mean TRYING to rip it off, and nothings budging.
- Replacing the battery in the remote. No changes.
- Switched to the Driver 2 key. No changes.
- Jumping it. Dash, interior, head- lights come on but only a few clicks, no cranks. Tinkered like this for several minutes and it finally started. Started strong when it did, no struggling to start, fired right up. Asking for radio code (as expected)
- Got it home and checked voltage while running (13.86) and while off (12.8). Perfect.
- Tried starting it again, same behavior.
- Removed the battery (DieHard Platinum that's less than a year old) and took it to get tested. Tests good making over 900 CA on the bench in the store. They did NOT charge it at the store, only tested it. I REALLY don't think its the battery.
- Bring it back and re-install. Car fires right up really strong.
- The battery. Basically new, high quality battery, tested at 900+ CA. And the car doesn't struggle to start. When it starts, it starts very strong.
- The Starter. A bad starter wouldn't cause the dash and all of the other accessories to be completely dead. If it was the starter, everything else would work fine.
- The Alternator. Its putting out 13.86 volts while the car is running and the car has never died on my while running. It only doesn't want to start.
Nika
Hi Everyone,
Nika
Nika
Thought I would respond to this just to show the results of my problem. It turned out to be the positive battery cable. There was corrosion all the way from the positive battery post to the starter. Very little corrosion on the battery terminal itself, most was inside the cable insulation. Was causing only 3v to get from the battery to the starter.
My issue was the MICU (Smart Unit) Driver side
Hi Everyone,
Nika
Nika
driver door still won’t detect anar but all else works.
gopeman
Feb 9, 2021 04:53 PM
wrxer
1G RDX Problems & Fixes
Jan 9, 2016 06:32 PM
