2012 SH-AWD - Metallic Sound While Turning
Hey guys,
I have this issue that is getting louder as time goes on. When I turn left I am hearing a grinding/metallic type sound. Going straight or turning right is no problem. No other drive-ability issues, as of now it is only a sound I'm hearing.
I've attached a video I took.
Could this be a bad axle?
Any help would be much appreciated!!
OP needs to inspect !!
Front pads were done before I got the car in June 2016 and everything has been fine until recently. I will definitely check though. It really sounds like a dust/heat shield that is rubbing. I'm super busy with work for the next week or so but will check when I have a chance and report back. Thanks guys!
Hey guys,
https://www.youtube.com/watch?v=JPyvmCARe-0
Let me know once you figure it out....I tried putting my fingers behind the rotor as much as I could to see if there is anything stuck between the shield and rotors but couldn't feel anything!
I didn't get a chance to update, but nismod05 was completely right.
I took off the tires to check and that is exactly what it was. I bent the dust shield back and the sound has been gone for 4 or 5 days now. I must have hit the dust shield when I was changing over to my summer tires.
Great when it turns out to be a simple fix like this. Thanks guys!!!
