2010 Acura TL Common issues
Hi.. a friend of mind is selling his 2010 Acura TL , base with technology package for $27k... it only has 10k miles on it... the price seems very interesting to me, but before I pull the trigger, are any common issues wth the 2010 TL that I should know ? Please advise......
Make sure you can live with the headrests, and the trunk space.
20-29 MPG depending on your driving habits - and that's on premium.
warranty would be transferable still, and still under full coverage.
It's a year old Acura; the biggest issues are going to be minor rattles that are usually easy to correct.
Only issue to report with mine has been the adhesive underneath the spoiler sticking out due to the hot weather we've been experiencing here in TX. No issues otherwise...
11K on my 2010 with no issues to report. Been back for an oil change/tire rotation and that's it. Typical Honda/Acura.
an adult perspective
Received 6,470 Likes
SHB, it sounds like a good price on a nice, low mileage car.
Let us know what you decide!
I've got 33,000 miles on my 2010 TL and aside from the dealer having to replace the radio at 10,000 miles [it would stick in the off position], I've had no problems to report. No rattles or other annoying noises.
No problems with my 2010 FWD TL Tech with over 25,000 Km on the clock. The headrests are fine for me. Best TL I've had even though the 2001 and 2006 were both very good cars.
I have a 2010 and it's been a dream so far. My wife also drives an 05 TSX with 55k on it and it's been solid as a rock except the light under seat heater button went out last year.
Trunk Hinge lubrication?
Can anyone advise on how best to lubricate the trunk hinges on a '10 TL? I have an annoying squeak in one of those hinges and cannot see how you can get to the hinge itself without removing all the trunk lining.
Any suggestions would be greatly appreciated.
TL-SHAWD 6MT Rocks!
48k miles, and my clutch squeaks when depressed, front doors rubber moldings along the glass on the windows were replaced. I guess they were warped by the TX heat...
Other than that, the car is solid...looking good still...
6G TLX-S
Back a long while ago with my 2G Integra, the clutch also squeaked while being depressed. The dealership applied some lub, which quieted the clutch for a few months. After the squeaks came back again, they replaced all the rubber grommets for the clutch return spring, and then no more squeaks ever.
2010 TL passenger AC no flow
Greetings! Having an issue with passenger AC not blowing air on my 2010 TL. Driver side works perfect. I can feel cold air on the passenger side vents, but not enough flow. Appreciate any help.
nsl752
14
12-06-2016 07:32 AM
