Puddle Lights on 4G :)
Waaaaaaaaaa.
Be sure to flush-mount though. I had them bracket mounted - doesn't do well with water.
I just pulled my skirts today and will be drilling 22mm holes and weather proofing everything. -30C Calgary weather sucks.
Looks great! Where did you get them and did you hook them up to come on with the interior lights? Also, any closup pics of the install underneath?
Waaaaaaaaaa.
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
They are hooked up to come on with the dome lights, so when you unlock/open doors they come on, and when you lock the car they fade out (just like the dome lights on the inside do - pretty sick). The dome light wire is behind the driver side fuse box which is a huge PITA to get to though.
I didn't take any underbody pictures of the bracket-mount install - BUT I actually have my skirts off right now ready to drill holes and flush mount them so I'll keep this thread updated with pictures and videos of them in action. I should be done within the next couple days.
Skirts are pulled:
![](http://www.kooty.net/photos/tl/IMG_0244.jpg)
Drill locations are marked up:
![](http://www.kooty.net/photos/tl/IMG_0247.jpg)
Waaaaaaaaaa.
Apparently there's another wire in the A-Pillar as well, but I didn't want to run the wire all the way so.
The puddle lights are a negative switch, so you'll have to find a constant 12V lead as well (which isn't that hard).
Waaaaaaaaaa.
UPDATE: I just came back from the store with a 22mm Hole Saw, Bit, Soldering Flux, and 16G Cable for my flush mounts.
I have to make sure that EVERYTHING is weatherproofed and perfect, because fixing a bad/broken connection is going to be 10 times than my bracket mount install.
![](http://www.kooty.net/photos/tl/IMG_0249.jpg)
Waaaaaaaaaa.
Might run 16G wire all the way tomorrow so I'll take pictures of the dome light lead location while I'm at it okay ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I'll make this a proper 4G TL puddle light DIY guide!
Waaaaaaaaaa.
Received 6,470 Likes
Waaaaaaaaaa.
Just finished flush mounting my lights and weatherproofing. Not a single problem so far. And it looks better because the lights are higher and have a wider spread.
Pictures to come over the next day or two!
BoricuaTL
04-08-2016 01:08 PM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
oyayjoe
09-12-2015 04:40 PM
