Puddle Lights on 4G :)
This has been in my mind for a very long time. I've been wanting to do this for a while. This looks really good, great work!! I'll definitely be doing this soon.
Originally Posted by 2010_TL
(Post 12625454)
Be sure to flush-mount though. I had them bracket mounted - doesn't do well with water. I just pulled my skirts today and will be drilling 22mm holes and weather proofing everything. -30C Calgary weather sucks. |
Looks great! Where did you get them and did you hook them up to come on with the interior lights? Also, any closup pics of the install underneath?
Nice!
Originally Posted by FAST4DR
(Post 12625676)
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123 They are hooked up to come on with the dome lights, so when you unlock/open doors they come on, and when you lock the car they fade out (just like the dome lights on the inside do - pretty sick). The dome light wire is behind the driver side fuse box which is a huge PITA to get to though. I didn't take any underbody pictures of the bracket-mount install - BUT I actually have my skirts off right now ready to drill holes and flush mount them so I'll keep this thread updated with pictures and videos of them in action. I should be done within the next couple days. Skirts are pulled: http://www.kooty.net/photos/tl/IMG_0244.jpg Drill locations are marked up: http://www.kooty.net/photos/tl/IMG_0247.jpg
Originally Posted by docboy
(Post 12625757)
Nice!
where did you wire this up to? diy?
See one, seen em all :chuckle: Nice work OP! First one on a 4G?
potmilkz, check the 3G garage.. |
yea i know that but how did you get it to work with the dome light? which fuse?
Originally Posted by AMUA6
(Post 12626541)
Originally Posted by potmilkz
(Post 12626724)
Apparently there's another wire in the A-Pillar as well, but I didn't want to run the wire all the way so. The puddle lights are a negative switch, so you'll have to find a constant 12V lead as well (which isn't that hard). |
:thumbsup:
I believe you're the first 4G to do this. |
UPDATE: I just came back from the store with a 22mm Hole Saw, Bit, Soldering Flux, and 16G Cable for my flush mounts.
I have to make sure that EVERYTHING is weatherproofed and perfect, because fixing a bad/broken connection is going to be 10 times than my bracket mount install. http://www.kooty.net/photos/tl/IMG_0249.jpg |
give a good diy on where to wire and such for us noobs!
Very nice! I would love to do this along with the light up door handles light the RL
Might run 16G wire all the way tomorrow so I'll take pictures of the dome light lead location while I'm at it okay :)
I'll make this a proper 4G TL puddle light DIY guide! |
Nice job.
looks great! just don't drive with them on...
its your car enjoy
Originally Posted by erick3
(Post 12629039)
Why would you need plumber's flux for a wiring job?
Originally Posted by princelybug
(Post 12627018)
:thumbsup:
I believe you're the first 4G to do this. +1.....Well done! |
Just finished flush mounting my lights and weatherproofing. Not a single problem so far. And it looks better because the lights are higher and have a wider spread.
Pictures to come over the next day or two! |
where did you wire the power to at the fuse box? diy please!
Looks Good! Do a video at night turning those lights on then TAKING OFF! Like a UFO!...Swoooshhhhhh! Did you tap the power wire into the power of the courtesy door lights?
they look great! i was thinking about getting puddle lights as well for my tl. my bfs 100% against it though. dunno why. hahah
needs diy write up!
