Installed my LED's
Installed my LED's
I got my LED's in for my license plate lights. I am still waiting on the ones that I ordered on eBay for the doors, they are coming from Hong Kong. Here are some pics and I will add more when I get the doors done. The last pic is a comparo between the LED's and my wife's RX350 Lexus with the factory LED's. Looks pretty nice in my opinion.
The LED's I got were .99 on eBay with $4.99 shipping. Here is a link. The ones I got for the doors are flank LED's that will point down at the ground with the horizontal install. They are also 1 Watt LED's.....
License Plate:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Front doors:
License Plate:
Front doors:
I thought about that... I will either have to reverse the harness installation spot or cut the harness off and crimp the wires back together in reverse.
I used the same license plate ones too, but haven't done the doors yet. Thanks for the link. Like you said, if the polarity is wrong, I will flip the wiring, because it won't matter if you have to put an incandescent bulb back in later.
Received 6,470 Likes
Very easy, the bracket that holds the lights to the bumper slides toward the front of the car and then you lower it and pry the clear shield off. Pull out the wedge bulb and install the LED. If it does not light, you have the polarity reversed, simply take the LED out and turn it around and put it back in the other direction.
Unfortunately, when I went back to look for a current auction the seller is no longer registered with eBay. I searched for Lexen LED and couldn't find anything either... I would just keep looking or check the web. My first pic shows what the package looks like. Hope that helps.
Guys, these are what I used in my TL as well as my new CX-9. They are extremely bright and look amazing. They have lights that shine down as well as all around. You can't go wrong with these. One pair is all you need. http://store.ijdmtoy.com/12-SMD-T10-...10_sku_c03.htm
Very nice. I have done interior, license plate, doors for my MDX, However, I had to end up to put the original light back to license plate. It didn't last long. It last about 6 months.
I just found and bought these from ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...4816&viewitem=
Hopefully these will work and will last more than 6 months, but if not... hey it was only 5 bucks.
Anyone that have these see more of a blueish hue towards the color or is it more just bright bright white lol. i see in the lexus with the Tl that lexus is more white while the one from the OP has it more white +blue hue. anyone wanna chime in>
For some reason, I can not figure out how to edit my first post, or maybe I am not allowed to, but here are the pics of the under door lights and another shot of the license plate with plates instead of paper tags.
I did not have to change the wiring at all in the door fo the LED's they only have a 1 Watt LED on one side of the board and the polarity in my car was exactly how it needed to be. So total install time was less than 5 minutes.
I installed these in my mdx and they are great!!
https://acurazine.com/forums/1-2g-mdx-2001-2013-166/installed-smd-led-license-plate-lights-pics-791551/
Greengecko
09-16-2015 08:19 PM
