XLR8 Brake Packages
Old Jan 2, 2012 | 04:25 PM
Road-Rager 1's Avatar
XLR8 Brake Packages
Does anyone have the kit installed on a 2009 TL? Need new rotors and pads and I was hoping to get opinions on the BBK package from XLR8.
Looking at the cross-drilled rotors with the ceramic pads. $470 plus shipping seems to be very competitive.
Oh yeah, if anyone has pictures of the setup on the vehicle or can guide me to where I can see what they look like, that'd be great.
Old Jan 2, 2012 | 05:14 PM
HeartTLs's Avatar
I'm have a set of cross drilled/slotted rotors (cheap stuff), I'll be upgrading to the XLR8 drilled/slotted package unless a reputable company makes 2 piece rotor that won't break the bank.
Old Jan 2, 2012 | 07:55 PM
alienstudio's Avatar
What are the chances of cross drilled discs cracking?
Old Jan 3, 2012 | 04:28 PM
Excelerate's Avatar
Former Sponsor
We have sold hundreds of these brake packages to the 3rd gen TL crowd. We have a sold a number to the 4th gen TL crowd as well. The packages include high quality rotors that are machined properly. The alloy compound is better than the OE compound and it is more durable than most of the other cheap companies on the market. The machining is precise as well.
Old Mar 14, 2012 | 12:18 AM
silver01cltypes's Avatar
i was looking at replacing my brakes soon on my 2010 tl awd.was wondering if anyone has put these rotors on there car.Do they hold up and look good behind the wheels kind of like the stock rotors or do they rust up fast?
Old Mar 14, 2012 | 12:37 AM
potmilkz's Avatar
these are not actually bbk's they just different rotors..
Old Mar 14, 2012 | 01:35 PM
Excelerate's Avatar
Former Sponsor
We've sold a lot of these rotors and pads to the Acurazine community. They use a power alloy compound and they are really well-machined. They also feature an e-coating, which is a durable black coating, that is applied to the hubs and vanes of the rotor.
Old Mar 15, 2012 | 10:35 AM
HeartTLs's Avatar
Josh I bought slotted/cross drilled rotors from a company in Cali over a year ago and although they perform better than OEM and are e coated black they're beginning to rust. Is that normal? Can you say whether or not the ones your offer in the package will do the same?
Old Mar 15, 2012 | 09:50 PM
Excelerate's Avatar
Former Sponsor
What part of the rotor is rusting? The part that was e-coated? What brand are the rotors?
Old Mar 16, 2012 | 10:54 AM
HeartTLs's Avatar
On the hub where it was e coated and all around the top of the entire discs which where not coated.
From 88rotors.
Old Mar 16, 2012 | 10:59 AM
potmilkz's Avatar
pics will help heartTLS
Old Mar 16, 2012 | 11:28 AM
HeartTLs's Avatar
I'll get on it in a few.
Old Mar 16, 2012 | 07:22 PM
Excelerate's Avatar
Former Sponsor
From 88rotors.
Take a look at this link:
http://www.stoptech.com/products/rot...er-slot-rotors
E-Coated Finish
Every Power Slot® rotor is finished with a black e-coating on both sides of the hat, inside the cooling vanes and on the outside edge. E-coating is a superior electro-statically applied finish designed to withstand 400 hours of salt water exposure without rusting. This is especially important on both mounting faces of the hat where it touches the hub flange and back face of the wheel. Any accumulation of rust in these areas can lead to installed lateral runout issues.
STOPTECH's e-coating is fairly durable. I've seen it last for years. Where the pad makes contact though oxidation will build up regardless; however the pad will burn it off.
Old Mar 17, 2012 | 10:42 AM
HeartTLs's Avatar
Thanks for the reply Josh.
Here you go:
Josh, AZ, what do you think? Is that normal wear for 1 yr (19k miles) in the NE?
Old Mar 17, 2012 | 11:03 AM
gibbyisgibby's Avatar
Mine are like that too, not very attractive lol
Old Mar 17, 2012 | 04:47 PM
HeartTLs's Avatar
Sucks :\ . What you got on, estimated mileage and time you've been using it?
Old Mar 17, 2012 | 05:49 PM
Treblig's Avatar
HeartTLs, Gibbyisgibby,
Would you guys mind sharing what brand of rotors you have?
Old Mar 17, 2012 | 11:46 PM
HeartTLs's Avatar
Mine are from a company called 88 rotors, I believe they're made in house.
Old Mar 20, 2012 | 01:04 PM
aspecallday's Avatar
This seems to happen a lot with acura cars.My last two did that after about a year of purchasing them.It hasent happened with my car now but this is the only one ive had the chance to park in doors.I'm not a 100% sure ,but maybe if a car is always outside the weather might start to effect certain areas.This is just a guess
Old Mar 20, 2012 | 07:06 PM
Edward'TLS's Avatar
6G TLX-S
I went through two sets of Rotora slotted rotors on my 2G TL; but they didn't show any rust elsewhere, except on the area which touched the brake pads. Even so, a few stomps on the brake pedal would clean out those rust.
Old Mar 21, 2012 | 07:28 PM
HeartTLs's Avatar
I cleaned them with soap and water, then caliper cleaner, then anti rust brush and finally reprinted them. They look great again!
Old Mar 21, 2012 | 09:53 PM
njsimons's Avatar
Glad you did just painting them makes suck a big difference.
Jul 16, 2017 07:33 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
