X pipe or J pipe?
Old Feb 15, 2011 | 02:40 AM
Richs09TL's Avatar
Bigrich1974
X pipe or J pipe?
What's the difference?
Old Feb 15, 2011 | 10:38 AM
Pete2010's Avatar
I believe x-pipe is for true dual exhausts (like the BMW M3). Jpipe is for what the 4G TL (and other TL's) have.
I'm sure someone else here can give more info.
Old Feb 15, 2011 | 10:39 AM
Teddybear's Avatar
Subsonic
you mean besides how one looks like an "x" and the other like a "J"? lol
i dont think we can use x pipes in our exhausts. x pipes are used for engines that are mounted lengthwise in the engine bay. their exhausts channel down the car parallel to the frame. an x pipe joins these pipes to even out the flow.
our tl v6's are mounted parallel to the front of the car. so the exhaust is collected into a single pipe that runs down the length of the car.
found both pics off google. the front of both cars is on the right side. they shouldn't need any more explanation than that... hahaha
Old Feb 15, 2011 | 12:57 PM
Richs09TL's Avatar
Bigrich1974
Thanx man I'm new to all this!
Old Feb 15, 2011 | 01:02 PM
Bearcat94's Avatar
AZ Community Team
You need to some way to balance exhaust pressure in the system.
X-pipe does it by "joining" the two out-flow paths. J-Pipe does it by bring two out-flows into one collector pipe (which may re-split later).
Old Feb 15, 2011 | 01:14 PM
Teddybear's Avatar
Subsonic
there's also an H pipe which is similiar to the X pipe.
Old Apr 18, 2011 | 02:40 PM
GoosedTL's Avatar
Proud owner of a GoosedTL
The H is the X ugly cousin!
Old Apr 18, 2011 | 05:52 PM
Livestrong_TL's Avatar
Irish_Viking
too bad the 4G didnt' have a true dual exhaust....not just look like it does...
Old Apr 19, 2011 | 08:38 AM
GoosedTL's Avatar
Its not too bad, that would be unneeded weight. They wouldnt have the performance aspect in mind if they did that. Someone mentioned it before but true duels are better for the big boys not so much our cars
Old Apr 19, 2011 | 09:07 AM
Treblig's Avatar
I'm also new to this, so what does the "J-Pipe" do for you?
Old Apr 19, 2011 | 09:21 AM
GoosedTL's Avatar
the J pipe is what we use to open up the backside. Basically the way the engine is setup (side to side and not front to back) the j pipe brings the exhaust ports into one pipe going back. It is also bigger allowing more air to pass through. The design was created to have performance in mind allowing it to give the best ains possible. The X pipe and H pipe do the same thing but for different engines and they have different end results in performance.
Old Apr 19, 2011 | 09:28 AM
Treblig's Avatar
What gains can one expect from the j-pipe and how does it affect the car's sound?
Old Apr 19, 2011 | 09:48 AM
GoosedTL's Avatar
I dont know what effects it has by itself if any really. But pair it up with the whole setup and the exhaust sounds good. Take a look at any sound clip on here and you can see with a full system it has a good throaty tone. I am not sure of numbers because no one that I have seen has actually put their car on a dyno and tested it out.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
johnpancakes014
Sep 27, 2015 12:58 PM
Rcelestino93
Sep 23, 2015 10:01 PM
