UR Crank Pulley Now Available!!!
CleanCL was kind enough to purchase a factory crank pulley and send it to us and we have confirmed with UR that the pulley is the same as the one for the 3rd gen TL (04-08). Maybe CleanCL can chime in but I assume he got the pulley for the AWD TL; we will have to cross reference the #'s for the FWD but I'm sure it will be the same.
On a positive note Acura actually took a hint and lightened up the factory pulley; this pulley was more than 2 lbs lighter than the 3rd gen TL OE pulley.
AZ Community Team
Received 7,771 Likes
If forget precisely for the 3G (which had the somewhat heavier OE Pulley), but I think the dyno gains were somewhere in the 7 - 10 WHP area (UR's site estimates 10 - 14 "HP Increase").
Assuming that is in the ball park (Josh perhaps can confirm or eloborate), the 4G gains should be slightly lower due to a little less wieght differential between the UR and OE pulley's and an assumed greater drive train loss in the 4G AWD.
Also the energy to move that extra weight can now be directed to the drive train. Ulimately, some will make it to the wheels.
Yes the gains might be slightly less since the factory pulley was a couple pounds lighter from the factory but there will still be gains and the throttle response is definitely improved.
acuratl26
04-23-2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
