Spark Plugs - Looking for Hotter
NGK and Honda have always meshed well. It looks like the NGK Iridium IX plugs would be what I am looking for to get a hotter spark @ WOT.
The part number that seems most likely to work is #2669. Has anyone bought these yet?
quite the contrary actually; you'd want to run colder plugs with boost/nitrous applications to reduce the detonation.
Lots of air = hotter chamber. Colder plug for better spark, otherwise the heat from the plug itself can ignite the fuel and cause it to detonate.
Hotter plugs = N/A application where you need to ignite the fuel faster and keep the air pumping in.
Sorry, what I meant was I've never see a reason to change the temperature on plugs unless you've gone forced induction. That's not to say a n/a motor wouldn't benefit from it, but for a vehicle like ours with bolt on modifications, never really seen anyone prove it one way or the other.
190hp? CL? That is around 60% hp of a 4G AWD.
Seems awfully low. I'd figure 240-250 at the tires minimum. Your numbers would indicate more than a 30% drivetrain power loss, which I suspect is the SH-AWD not dealing with the dyno or the dyno not dealing with the SH-AWD. My 03-CLS6M was putting 215 down stock on the J32A2 @ 260hp.
justnspace (09-25-2012)
Everyone's an expert, and no one reads. Like I said, we never took it to redline, the power kept increasing, this type of dyno reads lower than other dynos, and there is more drivetrain loss seen on an AWD vehicle. Factor all that in, and no, it's not all that low for what an AWD Acura typically runs on a machine. Not sure how comparing a FWD CL has anything to do with it, but you're the expert, not I.
acuratl26
04-23-2020 07:30 PM
ITSJESTER
17
12-06-2018 02:29 AM
Joe Avesyan
09-29-2015 03:57 PM
