Short throw shifter
Old Mar 26, 2012 | 09:37 AM
3rdGenHybrid's Avatar
Short throw shifter
Is there any shifter kits out there ? Didn't find anything, just figured the throws could be a little less
Old Mar 26, 2012 | 10:22 AM
FallenTSX's Avatar
None that I am aware of, and as far as throws go, its comparable to the S2K
-DeL
Old Apr 7, 2012 | 01:16 AM
Wa Gwan's Avatar
I own a 2012 TL 6 speed manual and the shifter is a short throw as it is.
Old Apr 7, 2012 | 10:32 AM
dragonwang's Avatar
I wouldn't recommend a short shifter. The stock shift system is smooth as butter. Adding a short throw would make it hard to shift. :|
Old Dec 10, 2012 | 02:04 PM
AcPimpin's Avatar
Leather so soft.
Is it smooth? Mine is a lil rough. I feel some resistance going into 1 and 2 gears.
Old Dec 10, 2012 | 02:09 PM
stella31's Avatar
I could just be making this up, but the shifts feel much smoother when they are a hair slower. In other words, ripping it gear to gear to get a quick change seems to really junk up the smoothness of the shift. Again it could just be in my head though...
Old Dec 10, 2012 | 07:07 PM
prepreludesh's Avatar
Colorado Springs
If you're feeling roughness in the 1st and 2nd gears, an easier solution would be to try and change out the transmission fluid with something like a GM Synchromesh or something similar. That has helped many-a manual transmission problems.
Old Mar 4, 2013 | 09:23 AM
ifixjetz1's Avatar
Depending on how cold it gets where you live, syncromesh gets really thick when cold. I had a cavalier back in the day with a 5 speed, and it was rough in the cold. I ended up using a Trick shift synthetic
Old Mar 4, 2013 | 04:20 PM
ucf_bronco's Avatar
I would be happy with some aluminum base bushings or even Delrin shifter bushings for under the hood. I had this combo (along with a STS) in my previous car and it made for some very firm shifts...I loved it!
Jul 16, 2017 07:33 AM
spoiler900
Oct 10, 2015 06:48 PM
MikeJM310
Sep 24, 2015 07:24 PM
