RV6 PCD + XLR8 J-pipe + Stock Cat + Stock Tips
Has anybody set up this combination?
If so, what are your impressions?
Any concerns?
Thanks in advance!
2011 AWD TL, 6MT
Any concerns?
Thanks in advance!
2011 AWD TL, 6MT
I have RV6 PCD + RV6 J Pipe (which deletes 3rd cat) + magnaflows + Stock tips. I would reccomend getting the whole RV6 package vs mixing and matching. Are you really worried about the 3rd cat after deleting the first two?
I think that mine sounds good - looks stock.
Not sure where tips come into conversation based on the mods you're listing...
I was stating the tips, just because i wasn't planning to change them. My only concern with deleting the 3rd cat is excessive noise and/or drone in the cabin, and smell.
Once u delete your primary cats, that 3rd cat doesn't make a difference... From experience it actually makes it raspier, I recommend high flow pre cats if your worried about exhaust being too loud
6G TLX-S
Will deleting the Cats set off the engine warning light ?
Changing the PCDs and J pipe has no effect on the appearance of the catback or mufflers.
People have reported this problem with the PCDs, throwing O2 sensor codes - I've been running them (on tank of gas number 3 now) and have not thrown a single code.
https://acurazine.com/forums/4g-tl-performance-parts-modifications-295/magnaflow-11225s-installed-853767/
The above is my thread (with sound clips) of in cabin on the expressway and ouside the car using magnaflow mufflers in addition to the PCDs and J Pipe.
6G TLX-S
https://acurazine.com/forums/showthread.php?t=853767
Driving habits will determine if you set a slow response for secondary o2 sensors. If I don't floor it and coast in 4th gear(manual trans only) it won't set the p0139/p0159 because the parameters for that code require accelerating in 4th gear(55-75mph) then decelerating. Since I've kept away from beating on it in 4th gear the code hasn't set, but every time I do, the light will trigger instantly, kind of wish I just went with the hfpcds.
How do you have your defoulers set up? I have mine pointed straight up (path of greatest resistance).
I've had test pipes on the majority of my vehicles the past 5 years. Using the defouler trick, I've never thrown a code on any of them.
This is the first one I've done with those nazi pre-cats though.
Former Sponsor
4drviper
09-23-2015 09:00 PM
STL TL-S
09-23-2015 08:52 PM
