Rear diff??
is it safe to have a nondealer change the rear diff fluid? or should i just bring it to the dealer?
I'm 50 miles past due for the rear diff fluid change. Is it recommended to change the fluid asap?
2010 TL AWD 6MT: New King
Just follow your MID, and you'll be okay.
A dealership can charge 2-3x what a "normal" auto shop charges. It does not seem too difficult IMHO, and one could even do-it-themselves. I had a local auto shop do a B16 service (car "inspection," oil change, tire rotation, and rear-diff change) for $89+tax.
Grandpa
Received 2,609 Likes
It is easy to do.
If you have a 2009 or 2010 TL, then the specification is for ATF Z1.
If you have a 2011 or 2012 vehicle, you will notice that the housing is now stamped DPSF for a new "Acura All-Wheel Drive Fluid" that began to be used in the 2011 model year.
We can assume that the friction modifiers are different, but I do not know if it is safe to use DPSF in a housing that is stamped ATF Z1, so I would just use the recommended fluid for the model year you have...pending a factory representative popping in here and recommending the contrary.
Unless you're doing something dumb like using your SH-AWD as the AWD Instructor car at Summit Point or something, I doubt you have to worry about the modified friction content of the new fluid.
When I was looking to get my transmission fluid changed out in my FX35 I checked with a local shop first for pricing. I asked them for the year make and model what they were going to use. The guy said just regular transmission fluid. I then asked if there wasn't any special instructions or types for Infiniti/Nissans. He said no.
I ended up having the dealership do it because I knew Infiniti/Nissan says specifically to use Nissan J matic fluid. JATCO, the transmission manufacturer states that it will not reimburse Nissan if their analysis shows a non comforming ATF was used. If you use anything else your warranty will be voided.
I mentioned this because I dodged a potential issue if I had listened to the local shop and wanted to save a few bucks. I don't know what Acura states for the TL but I'm a firm believer to just put in what came in the car when dealing with ATF.
^ Sorry I was trying to say know what the performance standards are for your differential and transmission fluids so that you won't void your warranty going outside of the dealership.
^ probably. but you should always double check. as far as the rear differential goes, it's essentially impossible to swap the fluid out incorrectly. there's only one fill/drain hole. in other words, it's impossible to overflow it (using the typical hand pump). just take it to your local mechanic or do it at home
Anyone found a comparable RedLine fluid yet? Switching from Honda MTF to Redline on my S2000 was night and day pedal difference on track days. I've used their water wetter for years too - but again, really only beneficial on track days.
They do make a 75w90 diff fluid - but not sure if anyone's tried it ?
BoricuaTL
04-08-2016 01:08 PM
