oem big brake kits
while there's nothing stopping you from swapping knuckles and calipers; the problem arises with the stock brake master cylinder and it's ability to keep up with the new hardware. with the 3G TL, we've found by doing the math that adding the RL calipers would result in a longer 60-0mph distance with a longer pedal throw.
but would that not be the same theory as bbk that people spend 2-3 grand for? being that its just bigger calipers and bigger pads and rotors? just been thinking if theres brackets made to swap the type s or rl 4 piston calipers instead of spending few thousands for about the same brakes
there is a wilwood kit (I believe it's wilwood) that bolts right up to the 4G and Wilwood actually took the time and money to do things right.
Again, there's NO stopping you from bolting up the knuckles and calipers from other acura's...Just know what you are getting into
I have the Stoptech BBK front and rear and it’s night and day difference in stopping power. Though the price is high, you get what you pay for. My buddy also has the trophies for his 4G and he has easily a $10k setup. Keep in mind that if you change your brake fluid to something more aggressive, you’ll need to flush out the old fluid and change it more often.
Stoptech did good by the 3G and created a kit that actually stops shorter than the base TL's...and it looks like they did you good by creating a kit that helps the 4G by putting in the time and money!!
OP, again...there's nothing stopping you from frakensteining your car. Just know you wont be gaining any advantage and there might even be a loss of stoppage. i always came from the mantra of...if you're going to do something, do it right!
see where im from there isnt many actual shows. and figured people here would know best so thanks and ill probably stick with stock for now with just better pads and rotors. just bought the car few months ago and just slowly piecing things together
I think what matters is the math. the Honda engineers worked very hard to provide you with the best stopping calipers, while keeping price down. Trust them!
@CarbonTSEX - Which Stoptechs did you get? I have been looking at these for years....LOL....
https://store.excelerateperformance....h/g-66163.aspx
How have yours lasted?
Do you drive in the winter with salt on the roads?
Will it clear OEM Stock 18's or do you need to go to 19's.
Upgrading your Pads, Rotors, Brake lines, and some redline fluid and you will be fine.
Capsu!e
24
Jul 29, 2018 07:53 PM
SilverBullet_RENAMED
Oct 31, 2002 10:55 AM
SilverBulletCLS
Oct 31, 2002 08:12 AM
