Intake question
Old Aug 24, 2013 | 07:59 PM
Bobby39's Avatar
Intake question
Hello everyone,
Have a question.. Will a K&N typhoon model number 69-1210TS fit the 2011 Acura tl 3.7? It says it'll fit the 2010 but for some reason it doesn't show of it'll work for the 2011. I would think it would fit but wanted to get a correct answer. Thanks in advance.
Old Aug 24, 2013 | 09:11 PM
zapco's Avatar
Yes...it will fit any 09-13 TL. All exactly the same.
Old Aug 24, 2013 | 10:51 PM
Bobby39's Avatar
Thanks for the reply. Does anyone know what this intake sounds like, is it a good intake?? Thanks
Old Aug 25, 2013 | 10:34 AM
zapco's Avatar
Should sound the same as a Takeda, they are both short air intakes. They sound really good; you won't be disappointed.
I run a CT icebox now but honestly can't tell the difference in HP....which is normal since it takes about 30-40 HP to "feel" in a 4,000 lb car.
Old Aug 26, 2013 | 11:39 AM
Excelerate's Avatar
Former Sponsor
Originally Posted by Bobby39
Hello everyone,
I don't believe so. The 3.7 TL has a larger throttle body so it won't fit unless K&N includes a larger coupler, which I don't believe they do.
Actually the 3.5 and 3.7 TL are different. There are different throttle bodies. So they aren't interchangeable unless K&N supplies two size couplers like TAKEDA does.
Old Aug 26, 2013 | 01:28 PM
elietania's Avatar
it supose to fit i asked the compagny and they said yes!
Old Aug 26, 2013 | 01:45 PM
FireAtWill's Avatar
Chief Excellence Liason
Well it's just a tube...like Excelerate said it's all a matter of whether or not they supply the right size adapters since the throttle bodies are different sizes. My Takeda intake came with a couple different adapters since the intake itself is only 1 size.
Old Aug 26, 2013 | 02:37 PM
AntSauce's Avatar
^they are correct. The intake is just a tube. Throttle bodies are different sizes. Check with K&N to see if they provide both couplers/adapters in the box. Otherwise, you can always find one separately.
Old Aug 26, 2013 | 04:41 PM
elietania's Avatar
Seriously you didn't see any difference? the ice box air intake it says in the spec you gain more hp then the k&n but why I don't know! and its almost the double of the price.
Old Aug 26, 2013 | 08:42 PM
zapco's Avatar
Im sure there is a HP/TQ increase...but not enough to say "WOW" because the car is big and heavy. Now if it was a 12-14 hp increase on a motorcycle....that would be felt.
I swapped out only because I wanted a real CAI and not a HAI.
Old Aug 26, 2013 | 10:59 PM
dirtyo2000's Avatar
Lol didnt really see a difference or feel for that matter lol. After doing the install I cant see where the big gains are supposed to come from. I will say that the factory one not only supplies the air box but the tubethat requires the battery box to be removed actually supplies cool air to the engine ccompartment
Old Aug 27, 2013 | 10:29 AM
AcuraTL's Avatar
OG
I can't tell you if I felt a difference from a stand still, as I do not floor my car often from a dead stop. However, during passing situations, I can definitely tell a difference in power. Like when I am going 55mph and I want to make a pass, before, I would need to drop down 2 gears (sportshift). Now, I only need to drop down one gear and it would go strong. The other good thing is the CT icebox does not add much noise, if any at all. My car does not need any more noise as sometimes I still find my exhaust noise unbearable especially when I have 2+ people in the car.
Old Aug 27, 2013 | 11:07 AM
deuce415's Avatar
The factory tubing seemed to pull air from underneath the front hood of the car around the battery, routed the air underneath the battery through a resonator looking box, then routed the air back out through a tube going towards the driver side wheel well, then up through the factory intake housing.
Whereas the CT intake pulls air directly from around the drivers side wheel in between the wheel well and the front bumper.
If you're really looking for a comparison, it would be more similar to getting any short ram intake, then sealing the filter element in a housing that pulls air from the bottom of the car.
Old Aug 28, 2013 | 06:47 PM
Bobby39's Avatar
Well I got the intake today, before I open it, I want to know if it'll even fit. Don't want to open the box, and then find out it won't fit. Thanks
Btw it's a k&n SRI model 69-1210ts. Says it fits the 2010 3.7, so I got it for my 2011 thinking it would fit.
Old Aug 28, 2013 | 07:11 PM
AntSauce's Avatar
It the Takeda SRI works for 09-13 and the CTE Icebox works for 09-13, I don't see why this wouldn't be the same.
Old Aug 28, 2013 | 07:30 PM
AntSauce's Avatar
Oh by the way, look inside the box to see if it comes with the 2 adapters or just 1. Worse case scenario, you go to your local hardware store or autoparts store and buy the coupler that would fit between the tube and the throttle body.
Old Aug 29, 2013 | 12:56 AM
deuce415's Avatar
There really isn't anything different between the 2011 and 2010 so you should be good.
Old Aug 29, 2013 | 08:51 AM
JP_TL_10's Avatar
That's exactly what I did, the adapter (reducer) that came with the SRI was probably for the 3.5L throttle body because it didn't fit on my 3.7L(¼'' to ½'' too small I would say so)....I found something that fits perfectly!
Old Aug 29, 2013 | 03:46 PM
Bobby39's Avatar
I got it installed today and everything works great. Only problem was the adapter part, my guy had to cut it to make it fit, and put 2 clamps in it to tighten it.
Old Aug 29, 2013 | 03:50 PM
AntSauce's Avatar
Glad it worked out. How do you like it so far?
Old Aug 29, 2013 | 03:57 PM
Bobby39's Avatar
Once the rpm goes above 3, the sound is sick. Love it!
Old Aug 29, 2013 | 03:58 PM
AcuraTL's Avatar
OG
I agree that the growl on the SRI is awesome.
Old Aug 30, 2013 | 11:35 AM
ActRightSB's Avatar
^^^ +1
Old Sep 1, 2013 | 09:47 PM
Bobby39's Avatar
I just had a SRI put in and now everytime I accelerate, I hear a whistle type noise with the windows open. When windows are closed, I hear nothing. Noise increases with speed. Anyone know what it can be?
Old Sep 1, 2013 | 10:40 PM
AcuraTL's Avatar
OG
That's the noise your engine is sucking in the air.
Old Sep 1, 2013 | 10:55 PM
Bobby39's Avatar
So the noise is completely normal? Thanks
cycdaniel
Dec 17, 2019 10:58 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
drone619
Jan 26, 2016 07:09 PM
IlliniAcura
Sep 19, 2015 09:31 PM
datadr
Sep 12, 2015 09:12 PM
