Intake
Old Oct 17, 2012 | 05:26 PM
Crj5181's Avatar
Intake
Is there a intake for 4 g tl 2012 FWD out yet? If so where
Old Oct 17, 2012 | 06:14 PM
CerberusKy's Avatar
yes, the SRI, but it will not do anything for you. Wait for the Comptech.
Old Oct 18, 2012 | 07:17 AM
Pseudomaniac's Avatar
I could swear there's a search button around here somewhere....
Old Oct 18, 2012 | 07:20 AM
the 4G TL comes with a cold air intake system STOCK.
if the short ram is only available, I would forgo that and just stay stock.
Remember heat is the killer of all things.
IAT's are warmer with a short ram intake, and this will retard timing!
Old Oct 18, 2012 | 10:39 AM
Crj5181's Avatar
Takada is it any good or difference as stock?
Thanks guys for input
Old Oct 18, 2012 | 10:42 AM
potmilkz's Avatar
takada is worse than stock.
thats the difference..
stick with stock, change your filter.
Old Oct 18, 2012 | 10:43 AM
Crj5181's Avatar
Cool thanks what filter do you recommend ??
Old Oct 19, 2012 | 07:37 AM
I wouldnt change the filter.
the stock filter, FILTERS the best and also lets in a pretty good amount of air.
the throttle body would be the limitation and not the filter.
Old Oct 19, 2012 | 08:34 AM
CleanCL's Avatar
I've had the throttle body bored and matched, switched over to Fram, and couldn't be happier. I get great gas mileage and the car has no problem breathing in air. I did spend some time researching air filters, particularly for Honda motors. Fram was the end result.
Old Oct 28, 2012 | 07:24 PM
23109VC's Avatar
it sounds like the SRI don't do much except make the car sound louder... but lose power.
I recall guys on the RL forum who put on SRI reported they felt their cars were slower too.... most said it wasn't worth the money and woudl not do it if they could go back in time....
a comptech intake - maybe that is somehow better? haven't seen one yet though..
Old Oct 29, 2012 | 01:16 AM
prepreludesh's Avatar
Colorado Springs
I don't think that it's ever been documented that the Takeda SRI has lost power. Of course, if people believe that it doesn't make additional power, that's one thing, but through the laws of dramatic responses, people have slowly but surely went from the opinions of "I didn't feel much power increase in the Takeda SRI" and continued to repeat and dramatize these reports to where it's now being reported "the Takeda SRI loses power!"
Also, I've documented on my Torque program that while the car is in motion with a Takeda SRI, that the Intake Air Temperature was showing only 8 degrees hotter than the outside ambient air temperature (this was all done on a car that had been running for 20 minutes). This is not enough to retard timing to lose power. Hell, it's actually probably the same temperature increase as the stock intake will get you.
Old Oct 29, 2012 | 07:58 AM
i64X's Avatar
This.
Any time someone throws just an intake on something and says that they felt any sort of gain or loss in power, especially on an NA car, you can be sure they're full of crap. Even if you sway +-4hp on a 3800lb 305hp car, you're not going to be able to "feel it."
Old Oct 30, 2012 | 01:49 AM
Edward'TLS's Avatar
6G TLX-S
Originally Posted by i64X
This.
And especially that the peak hp gain from an aftermarket intake is almost always located at the high rpm range, it is virtually impossible to feel the gain.
In addition, some aftermarket intakes actually generate a dip in hp at the lower rpm range before start gaining additional hp at the mid to high rpm range. So it is always helpful to look at the dyno chart rather than just reading the claimed numbers.
Old Oct 30, 2012 | 01:19 PM
dwest1023's Avatar
I did notice a slight MPG increase when I installed my SRI. Because of that, knew there was no HP loss.
Old Oct 31, 2012 | 06:09 AM
Colorado Springs
I also noticed an increase in MPG with my Takeda, although I did install it at the same time as I did my 3rd cat delete pipe. Previously, with just a J-Pipe installed I got 27.8MPG as my highest recorded MPG reading. After I installed these two items, my MPG jumped up to new record high of 29.5MPG on the same route with roughly the same outside temperatures.
Old Oct 31, 2012 | 10:53 AM
potmilkz's Avatar
i still dunno how you guys get soo much mpg.. i topped out at max 24mpg and that is with cruise control all the way to vegas from socal..
i think having an auto is a factor..
Old Nov 1, 2012 | 11:01 PM
23109VC's Avatar
the Takeda must sound bitchen though!
Old Nov 2, 2012 | 08:22 AM
ucf_bronco's Avatar
^^^ It does! I love the growl and the looks that I get as those RPM's creep up. It's also nice that it's only loud when you want it to be. I took a drive by video a couple weeks ago but my home PC is jacked up so I can't upload it. I will in the near future though.
Old Nov 3, 2012 | 06:33 AM
dwest1023's Avatar
only 24? wow. I seen 30 on my mid. I see 28mph even doing 70-80mph. must be the stick.
Old Nov 3, 2012 | 10:58 AM
stars_fan's Avatar
I get roughly the same and it's due to the heavier 19s and shitty tires my cpo came with.
I've never seen more than 25.6 driving max of 65 mph.
I'd love to swap some factory 18s and see the difference.
Old Nov 3, 2012 | 02:55 PM
Edward'TLS's Avatar
6G TLX-S
The factory 18" 's are still heavy.
Get some light-weight 19" wheels and light-weight tires, and you'll appreciate the improvement in mpg.
Old Nov 3, 2012 | 03:13 PM
alienstudio's Avatar
Would the 20" vossen be heavier than stock 18"?
Old Nov 3, 2012 | 07:46 PM
Edward'TLS's Avatar
6G TLX-S
For that you'll need to check with Vossen about the weight of your particular Vossen model.
Old Nov 7, 2012 | 04:43 PM
KB1Spec's Avatar
Got me a K&N Drop in Filter. Will test it out this weekend.
Old Nov 8, 2012 | 11:38 AM
01clsstock's Avatar
i am so smart S M R T
Question
So i guess no comptech ice box ever............
Old Nov 8, 2012 | 02:34 PM
EazyRider562's Avatar
Your going to love it bro!
Old Nov 8, 2012 | 03:48 PM
KB1Spec's Avatar
CT will make an ICE box...when I'm not sure yet...
Old Nov 9, 2012 | 08:54 AM
ucf_bronco's Avatar
I can't speak directly about this, but I replaced my stock 19's with 20" XO's / Hankooks and the weight was exactly the same. The stock wheels are HEAVY at 32 lbs (at least the 19's are, not sure of the 18's but I'd expect similar numbers).
Old Nov 9, 2012 | 06:16 PM
KB1Spec's Avatar
Just received my K&N Drop In Filter today. Model 33-2403. Simple install and took me 10 minutes. After installing the drop in filter, I start up my car and found a reasonable low end torque after 5 minute of warm up. I will find out about if there any increase of MPG as I just did my full fill up this morning. Even though it didn't give you a deep growling sound like any short ram or cai, but it is not bad for something which is about $45 SHIPPED
Old Nov 12, 2012 | 12:11 PM
I have a SRI made by K&N and I can't say enough about it.
Its danky!
Old Nov 12, 2012 | 12:52 PM
potmilkz's Avatar
im kind of skeptical about these filter things.. i think a factory filter which is half the price will pretty much do the same.. let us know on on-the-road difference is.. i may look into this as i need to change mine soon.
Old Nov 12, 2012 | 01:06 PM
Will doing this void your warranteee?
Old Nov 12, 2012 | 01:34 PM
CerberusKy's Avatar
I run this in my Maxima, and I think it is effective (butt dyno). Also, over the long run, it will save you $ on filters, as this is reusable. After x miles, clean it, oil it, put it back in and drive. I'm using the OEM filter in the TL for now.
Old Nov 12, 2012 | 01:49 PM
potmilkz's Avatar
i do agree with the re-usable factor, but i think i can shed out 25 bucks for a new oem filter every 4-6 months.
ive heard from many guys that used k&n that oil gets in to the MAF as the filter is oil based.. i will have to see in a long run if these actually damage the MAF.. but im leaning more towards dry filters.
Old Nov 12, 2012 | 03:20 PM
CerberusKy's Avatar
I have heard the same thing about the MAF. I probably have 100,000+ miles on my K&N without issue. For me it's not the $, but the convenience of not having to go buy a filter. I keep a good stock of oil and oil filters around, so I don't often go to the auto parts store/dept.
Old Nov 15, 2012 | 10:37 AM
KB1Spec's Avatar
Hmm...funny LOL
http://www.ebay.com/itm/K-N-33-2403-...70686710217%26
Description picture looks familiar....but ya that's a pretty good deal from them.
Old Nov 15, 2012 | 10:45 AM
Its all about the SRI K&N intake. I should be getting paid for how much promotion I do for them. Seriooooously!@
Old Nov 15, 2012 | 01:42 PM
potmilkz's Avatar
lol kb1spec they used your picture.
Old Nov 16, 2012 | 10:56 AM
KB1Spec's Avatar
Ya.....I wonder who is trolling this site......LOL
Old Nov 16, 2012 | 03:59 PM
wreak's Avatar
K&N is a very reputable company and have done several tests to show how their filters compare to OEM paper filters. I've seen some pretty impressive gains from them before.
