I want to take off catalytic
Old 06-09-2012, 12:59 PM
JesusM's Avatar
I have a 2010 tl sh AWD and I want to take off the catalytic and put a tube to make it straight pipe. Being that its sh-awd i want to know if anyone have done it and had bad feedback??
Old 06-09-2012, 06:04 PM
OG
AcuraTL's Avatar
Search function is your friend.
Old 06-11-2012, 12:41 PM
Former Sponsor
Excelerate's Avatar
We offer a test pipe that eliminates the third cat.
http://store.excelerateperformance.c.../i-300877.aspx
The third cat isn't monitored so it won't trigger a CEL.
Old 06-12-2012, 06:51 AM
Pseudomaniac's Avatar
Your Acura has 3 cats. The two "Pre-cats" coming out of the motor can be replaced with PCD (pre cat deletes) that turn those into straight pipes, or with HFPC (High Flow Pre Cats) both from RV6 Performance.
The third cat is in the traditional spot under the car, and can be replaced.
You can do a "longtube j pipe" and get power gains from what is effectively a lower header and from the built in "test pipe" which is the term for a straight pipe that replaces the third cat.
XLR8 I believe also makes just a test-pipe that removes this third cat.
The J Pipe and test pipe are relatively easy installs. The PCDs and HFPC are for experienced wrenchers - but are still just take-off / bolt on type parts.
You will see some power gains. You will probably see some check engine lights with the PCDs. No one has reported check engine lights with the HFPC, or just the J pipe, or just the test pipe.
I have a sticky guide at the top of the perfomance section describing mods. I highly reccomend if you're wanting power to explore the exhaust options first, because I found this to be the biggest bottleneck.
You have choices from XLR8, ATLP, Comptech, or a DIY with mufflers of your choice.
Read the forums - this whole section has all the info, very easily accessible, that you're looking for.
The following 4 users liked this post by Pseudomaniac:
DopeAcura (08-24-2012), justnspace (06-12-2012), lji (06-12-2012), ucf_bronco (06-28-2012)
Old 06-12-2012, 09:49 AM
JesusM's Avatar
08-15-2019 12:58 PM
Rcelestino93
09-23-2015 10:01 PM
jpm3071
NY/NJ
09-07-2015 08:25 AM
gavriil
09-01-2005 11:25 AM
Quick Reply: I want to take off catalytic
