eBay Deal: Slotted and Drilled Rotors and Pads
Old 09-13-2012, 08:52 PM
Packagingpro's Avatar
Anyone seen this deal? Slotted and Drilled Rotors with Ceramic Pads for $320.00 shipped! To good to be true? They look like the StopTech rotors.
Any opinions? Worth Gambling on?
http://www.ebay.com/itm/09-11-Acura-...1970%26ps%3D54
Old 04-24-2013, 11:02 PM
speedingbulletl's Avatar
So I came to Learn that Centric makes StopTech and PowerSlot and also R1 Concepts.. but I was wondering the difference in quality if you already had ordered. After much debate I'm looking at R1 Slotted and StopTech Slotted Rotors. Have you already made your upgrade?
Old 04-24-2013, 11:07 PM
Italiano's Avatar
First of all, don't waste your $$ on drilled rotors...Slotted are fine..If you want quality rotors,look at http://www.heeltoeauto.com/ and scoop up some slotted racingbrake rotors...
Old 04-25-2013, 12:17 PM
Former Sponsor
Excelerate's Avatar
You get what you pay for. R1 concepts is not STOPTECH. Centric also makes multiples lines of rotors, a basic rotor, a premium rotor and then of course STOPTECH's sports rotors.
If you want a good setup I'd recommend our AZ brake package.
http://store.excelerateperformance.c.../i-466576.aspx
http://store.excelerateperformance.c.../i-466577.aspx
Old 04-25-2013, 02:39 PM
ucf_bronco's Avatar
QFT! Brakes and tires...two things you should not go the cheap route with!
KarKraze (04-25-2013)
Old 04-25-2013, 09:20 PM
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Excelerate, please give your opinion on drilled/slotted rotors versus slotted only.
Thanks....
Old 04-26-2013, 08:56 AM
Former Sponsor
Excelerate's Avatar
Thanks....
For a street car it's going to be the same either way. The drilled/slotted just look nicer. However, I got some great info from STOPTECH at one time. I'm pasting it below:
Drilled are more prone to cracking in motorsports conditions. Drilled has the most bite followed by drilled/slotted, then slotted. On a street driven car, the appearance of the parts will have more of an impact than the performance difference as most drivers would not be able to feel a difference between the 3 options. All with have better bite than stock. Any track vehicle should use slotted only as that will be the most crack resistant.
Drilling and slotting is more about increasing bite than cooling. Some can argue that the added surface area can improve cooling as can turbulence, but it is marginal at best. Then again the weight reduction is also marginal so both arguments are somewhat moot.
The real amount of cooling a rotor can offer is going to be based on diameter and mass, as well as airflow through the disc by way of the internal vane structure.
Old 04-26-2013, 12:42 PM
HeartTLs's Avatar
Josh is it true that the slots in rotors tend to build up debris/brake dust?
Old 04-26-2013, 12:48 PM
Received 16,260 Likes on 11,971 Posts
this is not a concern.
Old 04-26-2013, 01:13 PM
HeartTLs's Avatar
How come? If they get filled out wouldn't that make them useless?
Old 04-26-2013, 01:42 PM
6G TLX-S
Edward'TLS's Avatar
Received 1,143 Likes on 817 Posts
Those slots are usually wide and shallow, and thus hardly any debris is able to stay inside, especially given the constant grinding action of the highly abrasive aftermarket brake pads.
08_UA7_Gr33k
02-11-2016 02:17 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
adreano17
09-29-2015 08:48 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
Quick Reply: eBay Deal: Slotted and Drilled Rotors and Pads
