Weird stereo problems
Old Aug 15, 2018 | 11:59 AM
dv-'s Avatar
dv-
2012 TL Base. Sometimes the radio turns on, sometimes it doesn't. If it doesn't, I usually have to turn the car off and on again before it will work. Sometimes if I hold the button down, it'll turn on eventually. Or turn on and off really fast. And the kicker: sometimes when it's on, it won't turn off, and the volume adjustments on the steering wheel won't work either. (Which makes me think it's not as simple as a dodgy power/volume knob.)
Is this something that people have experienced, and is there any kind of known fix? Is it as simple as finding a non-NAV head unit on eBay and swapping it in? (Security codes notwithstanding.)
Old Aug 17, 2018 | 08:56 AM
mossman77's Avatar
Check your battery and alternator. Weird things happen when improper or inadequate voltages are available.
Old Aug 17, 2018 | 02:15 PM
dv-'s Avatar
dv-
Thanks. Will have to dig around for my voltmeter.
The battery is original to the car, so it might just be time.
Old Aug 20, 2018 | 10:48 AM
mossman77's Avatar
Six year old battery...I would say so.
Old Aug 20, 2018 | 01:21 PM
dv-'s Avatar
dv-
Welp, I used it for a couple short trips yesterday, and today it was @12.42 volts. Unless there's something draining the battery, sounds like I need a new one.
Speaking of which, is there a way to check load on a battery while the car is sitting/off? I have a multimeter, but only really know how to check voltages and test continuity - dunno what most of the other buttons do.
Old Aug 22, 2018 | 12:13 PM
mossman77's Avatar
An auto parts store should have a battery load tester, but being 6 years old and sitting at 12.4, I would just save yourself the hassle and replace it. No guarantee this will fix your stereo issue, but you're due for a new one anyhow.
Old Sep 14, 2018 | 11:42 AM
dv-'s Avatar
dv-
Haven't had any problems since replacing the battery. Thanks again!
jptsx12
1G TSX Problems & Fixes
15
Jan 2, 2010 11:31 PM
earthbound741
Apr 3, 2008 08:56 AM
NYCAcura2.5TL
1G TL Problems & Fixes
Jul 28, 2007 09:57 AM
Amoeba
Dec 7, 2005 07:55 AM
robdog82
Oct 14, 2005 04:33 PM
