Weird stereo problems
2012 TL Base. Sometimes the radio turns on, sometimes it doesn't. If it doesn't, I usually have to turn the car off and on again before it will work. Sometimes if I hold the button down, it'll turn on eventually. Or turn on and off really fast. And the kicker: sometimes when it's on, it won't turn off, and the volume adjustments on the steering wheel won't work either. (Which makes me think it's not as simple as a dodgy power/volume knob.)
Is this something that people have experienced, and is there any kind of known fix? Is it as simple as finding a non-NAV head unit on eBay and swapping it in? (Security codes notwithstanding.)
dv- (09-14-2018)
dv- (09-14-2018)
Welp, I used it for a couple short trips yesterday, and today it was @12.42 volts. Unless there's something draining the battery, sounds like I need a new one.
Speaking of which, is there a way to check load on a battery while the car is sitting/off? I have a multimeter, but only really know how to check voltages and test continuity - dunno what most of the other buttons do.
An auto parts store should have a battery load tester, but being 6 years old and sitting at 12.4, I would just save yourself the hassle and replace it. No guarantee this will fix your stereo issue, but you're due for a new one anyhow.
dv- (08-22-2018)
