Valentine 1 hardwired to sunroof?
Well I tried tapping into the sunroof plug. The red with silver and black with silver. They were the biggest gauge wires of the bundle so I figured those were the ground and power feeding the sunroof switch. Didn't work though that's why I was hoping someone else had some luck with this method.
I cant see the pics but I think this is what you want https://acurazine.com/forums/showthr...hlight=Tweeter
and thats without tapping into any wire.
splicing or wire taps can cause shortages! if not done correctly.
Also agree with Justnspace, drop the wire behind the A-pillar down to the fusebox.
Then use a Fuse-Tap to tap out whatever (constant, ignition switched, etc.) +12V as needed to power your new accessory.
i did what jaxlxx did just bought a mirror tap and wired to my rear view mirror much simpler and cleaner install
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
deyainrdy4ds
Sep 22, 2015 10:15 AM
